you need to make sure you actually select the right device for recording for whatever u use it for. If your using it for msn for example run through the call set up thing and make sure its selecting your usb headset for recording and not your sound card.
And same in your control panel make sure your usb headset is set as the device for recoding and not your soundcard.
Also did u install the drivers if it came with any.
