Logitech X-540 Speaker System front left low
16 Jul 2008
London
Hi,
Have a issue, when running the 5.1 sound test through windows or through Asus Xonar DS Audio on my Logitech X-540. The front left speaker always sounds extremely low, unless I put my ears right to the speaker, its the only way I can hear it, all the other speakers including center and subwoofer sound fine.
I have tried swapping the left and right speakers round which seems to have the same effect, so I don't think it the actual speaker.
Can anyone shed some light on this problem?
Thanks
Do you plug them into the bass unit like most systems? If so I can only assume the issue is in the bass unit and not the speaker. Have you tested another pair of speakers/headphones to see if your output is the issue (I.E. your jack port)?
Hi,
Thanks for your reply. I managed to fix it, I unplugged everything, then connected everything back up, maybe something was loose.
