Logitech Z-4 2.1 Speakers
24 Nov 2005
Hornchurch, Essex
How would I use my xbox 360 with these? I basically have a red and white phono from the xbox 360 and need to connect these up. What adapter would i need and where would it plug into? Just want to make sure these speakers will actually work with my xbox 360 not going via the pc inputs before buying them. Thanks
It looks like the Z-4's connection can be removed at the back of the sub (I'd like confirmation if someone has them). Providing it connects with a 3.5mm stereo socket (like every set I've seen) then a standard 2xphono - 3.5mm jack cable will work (the type commonly used to connect iPods to Hi-Fi's) :) . If nothing else you can connect like this via the aux input on the wired remote, but I expect you can connect around the back as well.
EDIT - A review I found shows the back/connections and it appears to use the 3.5mm jack I hoped it would. This is the cable type you want (ignore the gold adapter), its pretty common but most places that sell them are competitors.
I read "red and white phono from the xbox 360" as meaning sockets, you have trailing leads with phono plugs attached? In that case a splitter is what you want (or that cable but with sockets rather than plugs).
Yes I have leads with phono plugs from the 360 so I would a phono socket to mini jack splitter which I already have so i'll be getting these speakers. Also you said they have a 3.5mm input so thats cleared up things for me. Thanks again :)
