Logitech Z-5500's producing a really annoying popping sound
14 Apr 2004
UK
As above, it has now been occurring since I bought them, I always had the impression that it'd go away but now it has started producing ever so slightly more frustating popping noises.
It has also started producing a humming sound if the speakers are turned on.
There is no interference, as everything is well placed.
I know some people here had the same issues, how did you resolve it? I'v gotten to a point when my headaches just can't handle the random popping throughout the day on a daily basis.
Its most likely electrical interfirence on the power line. This speaker set is unfortunatly very sensitive to it. A good power stripe that included emi protection does minimise it.
Ive had the same issue from day 1 with my logitechs as well. Im living in an apartment off campus and whenever my roommate turns on a light or tv in his room it causes my speakers to pop so its never a random thing.
Anyways I remember reading you can get one of those backup power supplies to clean up the signal and help maintain a consistent power current to the speakers.
Just parroting info here but I have heard that this can be caused by the EM field from the gigantic subwoofer, have you tried moving the sub further away from the sattelites?
I only brought my Z-5500 last saturday(3 days ago) and there doing this popping noise :( ..
Sounds a bit like the amp is turning off and on.
I do wonder how logitech speaker sets get THX certification when they pick up and amplify interference/LineNoise so easily :/
My sentiments too :confused:
I mailed Logitech and here's the reply I got:
Dear Mr. ******,
Thank you for contacting Logitech's Electronic Technical Support.
I understand that you experiencing popping issues wit your Logitech Z-5500 Digital.
At this moment we are working on a solution of this issue and we ware taking this very seriously.
But right now I can not give you a solution about this issue.
Can you contact us again over a month and check for an update, to see if we have a solution for this issue please?.
My apologies that I can not help you right now, but we are investigating this issue.
If you have any additional questions regarding your product, please feel free to visit our website at http://www.logitech.com
Kind Regards,
Ralph Schipper
Logitech Europe SA
European Customer Support
Didn't expect much of a reply, they make it sound as if it's a new issue.
