Logitech Z333 Speakers not working
30 Oct 2014
Norfolk
So got new speakers,logitech Z333, and its plugged in, shows sound input and output but no sound. Usually I got a interface to change between headphones and speakers etc..not sure how to get it up
or what settings
There's two sets of RCA connectors on the back of the sub; one set for the satellites, the other for the input. You did connect the satellites to the grey and blue RCA connectors?
Uhm, theres 2 side speakers and its blue and black cables, and the other is small black plug, which I plugged into the black port of my sound card
Motherboard audio or sound cards that use colour coded sockets, the black one is for the rear speakers. If you've set the output to stereo/2.1, and got the speakers connected to the black socket, then that is one reason why the sound is not working.
You need to connect them to the green, which is for the front left and right speakers.
If it's still not working, then there must be something else though if you have them connected up OK.
did you get these working? Im looking at a new set of speakers and like the look of these so would like youre opinion
Regardless of onboard (Realtek) or the Asus DG, both "sound devices" will require driver install to function.
Just install the drivers, and then select the device to use in "sound property" of Windows.
To quickly test the speaker to make sure it works, you could just plug the 3.5mm connection into the 3.5mm audio jack of a phone or tablet.
