5 May 2007 at 16:22 #1 neocon neocon Soldato Joined 24 Aug 2006 Posts 6,241 are the speakers wall mountable? looks like its 2 screws for each speaker, ca anyone confirm?
5 May 2007 at 16:23 #2 NokkonWud NokkonWud Caporegime Joined 1 Oct 2004 Posts 26,316 Location Redcar Yes, they are wall mountable and it is 2 screws per speaker.
5 May 2007 at 16:35 #4 neocon neocon Soldato OP Joined 24 Aug 2006 Posts 6,241 do you know how long the speaker wires are? can you use your own wires?
5 May 2007 at 18:50 #5 Phoenix211 Phoenix211 Associate Joined 28 Mar 2004 Posts 1,992 neocon said: do you know how long the speaker wires are? can you use your own wires? Click to expand... you can. The manual tells you what type.
5 May 2007 at 19:19 #6 rocketman rocketman Associate Joined 5 Dec 2006 Posts 230 The feet swival round to act as the wall mounts. Just don't remove them from the actual speakers, as you'll never get them back on
6 May 2007 at 00:09 #7 doopydug doopydug Soldato Joined 18 Oct 2002 Posts 2,826 Location Fife neocon said: do you know how long the speaker wires are? can you use your own wires? Click to expand... You can use your own wires - there are 3 15ft ones and 2 25ft ones suplied if i remember correctly
