Hi all.
I recently bought a Logitech z906 surround system to connect to my gaming pc and tv.
I have had issues getting it all setup hence this thread i made.
I connect the subwoofer too my Logitech main receiver{not sure on the name}.
I then connect the 6 pin connector too the rear of my subwoofer then too the rear of my pc{which is color codded differently....great}.
I have ordered an optical cable as i will hopefully then be able too hook it up to my tv correctly.
I just can't get surround sound working.
I use a msi gaming pro carbon ac motherboard.
The speakers just aint working all of them, if i get them working at all the sounds seems to come from, the front 2 satellite speakers mainly.
Any help will be great.
And also have some serious lag issues with a Logitech mouse and keyboard combo i bought mk270.
Constant lag and delay, they was find since i bought them but recently something must be interfering with them.
I have changed batteries.
