Lokking for new case to replace antec 900.
2 Nov 2003
Hi
Im looking for a new case plan on running 2 x 480 gtx sli so it needs to be roomy inside and have good cooling.
Have been looking at the Antec 1200 or Haf 932 but i would like people advice please or suggestions.
I dont think you would go wrong with either of those cases as they both have superb air flow. Though just to throw another case into the mix ... Cooler Master ATCS 840 :)
It meets all your requirements as its super roomy with great cooling ... comes as standard with 3 x 230mm fans (2 roof mounted as extraction and 1 front mounted as intake). You also have 1 x 120mm rear extraction fan and you can add another 3 120's inside and even add another 120mm rear PCI slot hot air extraction unit for grahics cards (might be a gimmick as Ive not tested it yet). Very subtle styling compared to the two other choices but looks very very nice :)
...yes I own one .
...yes I own one .
Im watching a video on it now and it does look really good.
What I love about it is that it comes FULLY filtered even the base fan (which isnt supplied .. 120mm ) still has a filter which is easy to remove for cleaning.
Oh and you can order a windowed side panel for them if you want though the inside is mainly silver with black trim rather than all black it still looks good :)
