Lol@ my eclipse
26 Dec 2004
Sweatshop.
i took the panel off a few saw the mod i did with the mesh its now become rusty! which is pap, so i took it off i now have a window without a window. so ive now put some fans where the window should be, hard to explain.
just gotta dust regulary now :)
will be ok wont it?
-Neoni.
:eek:Lol pls post some pics .... :D Should be interesting... , what type of fans did u use? with led's or just normal ones?:confused:
does that mean there was moisture inside the case?
i dont think the mesh stuff i bought was rust free?
it looks fine imagine it with a plastic window, take the window out, and replace every plastic screw that holds the window in with a silver capped one. and then a fan mounted on one of the screw holes to cool the gfx card looks sweet, i dust it everyday to make sure it doesnt get too dusty :)
