Hi,
I'm after a new PSU for my system. My old PSU isn't quite up to what I plan for it. And I've noticed that it's cables can't reach the placement of all the power connectors on the Abit IP-35 mobo I'm installing in my case (Lian-Li V2000). That lack of reach has led me to upgrade a little sooner than I was planning.
As I survey the range of quality PSUs out there in the 700-900W range a few questions come to mind. Hopefully, some of you guys can fill in some of the blanks and any additional background:
1. Modular PSUs seem attractive. Is it possible to buy extra long cables modules?
2. When dealing with quality PSUs is modular cabling as attractive as it appears? ie, do quality PSUs like the PP&C 750W (I like this) have enough cabling options to meet anyone's needs? And are those cables long enough for a V2000 style case?
3. Do some PSUs have longer cables than others? Or will I be forced to add cable extensions?
Given these points and the general guidelines given above is there a PSU best suited to my case, mobo and power/quality requirements?
Thx
D
Thx
D
