Long-distance USB hub
18 Oct 2002
I’m setting up my lounge HTPC/gaming PC in a cupboard in the utility room next to my lounge. The motivation is to have less clutter in the lounge and no noise.
The plan is to have a USB hub behind the TV in the lounge into which I can plug various receivers for my remote, keyboard, gaming controllers etc. None of the devices need anything more sophisticated than USB 2.0.
The cable distance might be stretching the limit of USB 2.0 (15 feet, I believe) and having a number of devices plugged in means I’m expecting to have a powered USB hub.
So, if I use a powered USB hub, can the cable between the PC and the hub be longer than 15 feet?
And does a hub with a long cable exist or will I have to be creative?
Many thanks.
You want an Active Cable. USB 2 active cables are cheap - a bit over a tenner - and you can get a 10 metre cable with a 4 port hub on the end. An alternative is a pair of adapters that convert USB to ethernet and back.
You’ll be hard pressed to find a hub with an active repeater attached, it’s too niche. You need to connect one to the other.
So, based upon what Quartz suggested, I’ve found a UGreen 10m USB Extension Cable with 4-Port USB 2.0 Hub which claims to be active, therefore potentially ticking every box.
If not, from what you say, it sounds like I can use a single active USB extension cable and then just attach any old USB hub on the end.
Is that about right?
Yup :)
