- 14 Dec 2005
- Bath
Hi Guys,
This is for a friend's connection not mine, I live in the city and sync at a nice 13mbps
. They were moaning about the lack of speed they get, so I was doing the usual "LOL BT are ****, switch to Be/O2".... until I saw their stats! One thing to note is that they are (straight line distance) approximately 5.54km from the exchange. Sounds a bit like Fox's situation then!
Yeah, you read it right.... Sync of 576kbps
Any ideas on what to do welcome! Change the router? Change to ADSL2+ on O2/Be (they've got LLU on that exchange). Play around with the phone line? Set a target SNR?
BT Home Hub said:Uptime: 0 days, 3:34:24
Modulation: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 288 / 576
Data Transferred (Sent/Received) [MB/MB]: 10.72 / 101.74
Output Power (Up/Down) [dBm]: 11.5 / 16.0
Line Attenuation (Up/Down) [dB]: 31.5 / 63.5
SN Margin (Up/Down) [dB]: 24.0 / 19.5
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 0 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 2,098
HEC Errors (Up/Down): 0 / 367
Line Profile: Fast
