Hi Guys,
I was wondering if I could run a potential build past you guys for some advice/suggestions etc. It's a long overdue upgrade from a C2D system.
I'm after building a kind of all round system, as i do use my current system a lot, and it's starting to creak under the loads it deal with daily now. I do a fair amount of work with virtual machines, and quite often have a few running concurrently.
Photoshop / illustrator are used constantly throughout the day, and large files are not uncommon. I don't really do a huge amount of gaming, but there is some. Nothing too intense though, some Counter Strike source mostly. Although I suspect if I've a more capable system, I probably would play more?
I'm also now just getting into some video work too, but again, nothing too major for now.
One critical thing is that I need to run dual displays, and i'm looking at iiyama 24" led monitors, Slim Bezel is a must.
However since I last bought a graphics card, the world has changed, so I could really use some advice here. Currently using a Radeon 4670, so pretty much most things would be better today.
Quietness would be nice too, as this will be in my dining room, and i'd rather not get ear ache for it sounding like a jet engine. not looking for silence, but I can't have it sounding like a HP Server on startup
Taking the above into consideration, the spec I'm looking at is:
It will be running Windows 7 pro 64Bit - as I already have this
Lastly is a Corsair Vengeance 2100 Wireless Dolby 7.1 Headset - working late in to the night, i need a comfy wireless headset so as not to wake mrs.
Case wise, Id like something plain black, preferably not with a front door on it, and ideally with USB sockets and power near the top of the chassis.
I'd like to hear your thoughts on the matter, especially on the RAM and PSU, as I've done some reading on other forums, and the corsair RM range were not too well received.
I know it's rather a high spec for what I need, but i'm hoping to get a few years from it before an upgrade
Thanks in advance guys
Chris
- Intel Core i7 4790K or 4770K
- Asus Z87-PRO, Intel Z87, S 1150
- Corsair H80i Hydro Series CPU Water Cooler
- 32GB (4x8GB) Corsair DDR3 Vengeance Jet Black, PC3-14900 (1866), Non-ECC
- 250GB Samsung 840 EVO Basic SSD SATA III 6Gb/s - for OS & APPS
- 80Gb Intel 520 SSD - Already have this for Virtual Machines
- 500Gb SATA3 WD - from Current System for work etc.
- 3TB WD WD30EZRX Caviar Green SATA 6GB/s IntelliPower 64Mb Cache 8ms - Storage of Work / pics / Music etc
- Corsair Carbide Series 300R Black Mid Tower or similar...
- 550W Corsair RM550
- Dual ASUS DVDRW - From Current System
- 2GB EVGA GT 740 or Something similar.
Chris
