Long Overdue Upgrade
8 Mar 2025
Worcestershire
Hi all,
I'm finally looking to build a new PC, must be about 7 years since the last full build and a couple since upgrading to a 2060 Super and an SSD or two. This will mainly be for gaming as the current build is struggling, however I still plan on using it for watching the odd DVD here and there!
Ideally looking for a smaller case (currently sat with big old Cooler Master case - CM690 I believe!) although I still need space for a DVD drive or recommendations for an external one?
Probably have a budget of around £1500 and I've been looking at a swap back to AMD, considering one of the new Radeon cards and also looking into a new modular PSU.
Thanks in advance for any recommendations!
Here's an AMD build, the case says it has 2x external optical bays?
I could only add 1x 9070 card to cart, the rest are unavailable, so this isn't something I recommend you buy.
My basket at OcUK:
Total: £1,514.86 (includes delivery: £11.98)​
You might want to look into the Pop range (Fractal), I believe they have a hidden drive bay at the bottom?
