long rang wireless keyboard + mouse
18 Aug 2004
midlands
hi,
which keyboards and mice have the longest range of signal?
need some for my pc in my living room
thanks
nickels
The gyration go 2.4 offers a 10metre range,the mouse can also be used in the air as you would a remote control,great for media pc's.I've got the older set,which I use for my own HTPC.
Very good but quite expensive.
quite expensive HAHA its £185 :p anything abit cheap ?
My Logitech G7 mouse will work from the other side of the flat...
Reciever underneath my monitor (within 4" of it) and also passing through the G15 keyboard & stereo with monitor on top... Through the kitchen and a bedroom.
Quite simply the largest range of any wireless mouse I've used.
If I get a chance I'll try it from the front door of the flat... Or even outside the flat. :D
It works on the standard wireless frequency (2.2 GHz) rather than the standard wireless mouse frequency (11 MHz) so has the equivilent range of a wireless router.
No idea on their keyboards - I use wired ones.
