- 10 Nov 2009
- London
I have a gaming PC upstairs with a 24inch monitor, and while this is perfect most of the time it has occurred to me that it would be quite nice to be able to hook it up to play games downstairs on the 40inch sometimes. Without moving it
My plan:
- 15m metre HDMI cable
- XBox 360 wireless USB controller
- Setup the controller so it will work as a mouse, this should be good enough for launching games.
The main bit I'm dubious about is the range of the controller. There's probably about 15 foot straight-line distance between the sofa and the upstairs PC with only 1 wood floor in between. I don't have any experience with wireless controllers though, will I get away with it? If not is there an alternative solution?
Is there any other reason this won't work? It'd be a bit annoying to buy the stuff, route the HDMI cable and only then discover it was a follish plan!
My plan:
