I've a Blues Junior and a Cort 335 copy, however no way to record it [this is a lie actually, see below
![Stick Out Tongue :p :p](/styles/default/xenforo/vbSmilies/Normal/tongue.gif)
But it sounds absolutely fantabulous. Lovely, mellow warm blues sound on the neck pickup. Middle selector is also lovely. I don't use the bridge though. I have a v-amp which can't even begin to get any kind of similar tone.
Also use it with a USA Fender Strat, sounds good, but not as good as the 335 copy
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
Actually, I do have a way to record it, I've got a £15 headset which I've rarely used.. Quality is poor, but it might give you an idea:
here.
(you might need to turn your volume up a bit)
Starts with neck/bridge pickup, no fat button, a little reverb on the amp, no pre-amp overdrive. The volume is at a bedroom practice sort of level. Switch to the neck pickup at about 50secs. Then bridge pickup. Then switching between the three positions. I stick the fat switch on at some point (maybe 1min 40 - probably with middle pickup there). Briefly turn up the pre-amp overdrive. Then turn up middle, down the treble, no fat, and turn down the tone control down somewhat on the neck pickup for a more jazzy sound. It can go more bland than that though if I turned the tone down totally. Then, er some other stuff that I can't remember.
