- 20 Oct 2002
- Derby
As per title, does anyone know of an alternative to that Peerless Precision Gear Adjustment Projector mount that has a similar type of adjustment?
I have thought about getting some use out of my Sony HT Projector that unfortunately has been gathering dust for a few years. One of my issues is that i only have a cheap mount for the projector which can be a little wobbly and can lose its alignment which makes it a chore to use the projector as it has to be constantly realigned. I have seen that there is a mount called Peerless Precision Gear Adjustment Projector mount which has adjustment gears that have nice little clicks rather than move to position, tighten if it need adjusting loosen rinse an repeat etc. The only issue that i have is that they are about £180 which is a lot more than i can afford to spend on it.
Does anyone have any alternatives that have a similar mechanism to this that is a bit more budget friendly?
Any help would be appreciated.
