** LONG WEEKEND DEALS TO CELEBRATE INSOMNIA i52 **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We have some stonking great deals to celebrate this long bank holiday weekend Insomnia event, check them out, some will end Tuesday next week and others Wednesday:-
AMD Piledriver FX-8 Eight Core 9590 Black Edition 4.70GHz (5.00GHz Turbo) (Socket AM3+) Processor - OEM @ £173.99 inc VAT
Unmatched multitasking and pure core performance with a new architecture. AMD FX Processors unlock maximum, unrestrained processing performance for extreme responsiveness you can see and feel. Experience unmatched multitasking and pure core performance with the industry's first 32nm 8-core desktop processor. Get the speed you crave with AMD Turbo CORE Technology to push your core frequencies to the limit when you need it most. Go beyond the limits of maximum speed. But the best part of all? You'll get all this impressive performance at an unbelievable price. You'll be asking yourself "what competition?" in no time.
Features:-
- The industry's only 8-core desktop processor
- Overclock with easy to use AMD Overdrive™ and AMD Catalyst Control Center™ software suites
- Supreme power available from virtually every core
- Aggressive performance for mega-tasking and intensive applications like video editing and 3D modelling
- The industry's first and only native 8-core desktop processor for unmatched multitasking and pure core performance
- New 32 nm die shrink designed to reduce leakage for improved efficiency, increased clock rate headroom and better thermals
- Can deliver more cores and more performance without raising the power requirements
- Unlocked processors allow the maximum tuneable performance
- AMD Turbo CORE Technology dynamically adjusts performance to give you the best experience, no matter what you are doing
- Get superior performance at a competitive price with unlocked technology
Specification:-
- Multiplier Unlocked
- Eight Core Technology
- 4.70GHz Clock Speed
- 5.00GHz Turbo Clock Speed
- 5.2 GT/s System Bus
- AM3+ Socket
- 8MB L2 Cache
- 8MB L3 Cache
- 64-Bit Technology
- TDP: 220W
- Voltage: 1.4125v - 1.6500v
- 32nm technology
- Support upto 2400MHz DDR3
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan NOT INCLUDED: We recommend Alpenfohn K2 Mount Doom or watercooling
Was [£209.99] Inc. VAT
Only £173.99 inc VAT.
ORDER NOW
Asus GeForce GTX 780 Direct CU II 3072MB GDDR5 PCI-Express Graphics Card @ £341.99 inc VAT
NVIDIA GeForce GTX 780 is now great value for money with technologies such as GeForce Experience, TXAA, 3D Vision 2.0 making the latest games such as Titanfall not only look out of this world but playable with silky smooth frame rates.
The newly arrived ASUS GTX780-DC2-3GD5 ships with 28nm GPU and 3GB GDDR5. To fully harness the power of new GPU technology, ASUS GTX780-DC2-3GD5 built with ASUS exclusive DirectCU II design featuring a 40% more efficient 10mm copper heat-pipe, 2.2X larger dissipation surface are and unique CoolTech fan that ensures 30% cooler and up to 3X quieter performance than reference. For enhanced overclocked headroom and gaming experience, ASUS redesign GTX780 with DIGI+ VRM offering precise digital delivery for better software overclocking stability. For enhanced overclocked headroom, ASUS GTX780-DC2-3GD5 uses 8+2 phase power design in Super Alloy Power technology, compared to 6+2 phase power design in reference card. In addition, GPU Tweak utility helps users modify and tune boost clock speed, power target, temperature target and fan performance via an intuitive interface. This card uses PCI Express 3.0 as the standard interface, doubling the data bandwidth of PCI Express 2.0. The power of ASUS GTX780-DC2-3GD5 also supports NVIDIA® Adaptive VSync technology and 3D Vision® surround™. ASUS GTX780-DC2-3GD5 provides fantastic gaming experience!
Features:-
- 30% cooler and 3X quieter performance with ASUS exclusive DirectCU II thermal solution
- ASUS uses 8+2 phase power design in DIGI+ VRM and Super Alloy Power technology for precise digital delivery and enhanced overclocked headroom.
- GPU Tweak utility allows you to tune graphics card performance and check card status via an intuitive interface
Specification:-
- GPU: GeForce GTX 780
- Core Base Clock: 863 MHz
- Core Boost Clock: 902 MHz
- Memory Clock: 6008 MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£389.99] Inc. VAT
Only £341.99 inc VAT.
ORDER NOW
Asus GeForce GTX 780Ti ROG Matrix 3072MB GDDR5 PCI-Express Graphics Card (MATRIX-GTX780TI-P-3GD5) @ £499.99 inc VAT
The ASUS Republic of Gamers (ROG) Matrix GTX780 Ti is a new graphics card that squeeze breathtaking performance from the latest GeForce® GTX 780 Ti graphics-processing unit (GPU).
ROG Matrix GTX780 Ti has been built on the renowned and highly-trusted ROG Matrix legacy as the coolest, quietest and most-readily-overclocked graphics cards available. DirectCU II cooling and CoolTech fan technologies combine with the brand-new Memory Defroster feature to create the perfect balance between spectacular power and out-of-the-box simplicity - all dressed up in the seductive ROG wardrobe.
With support for next-generation 4K/UHD (ultra-high-definition) gaming resolutions of up to 4096 x 2160 pixels, the Matrix GTX780 Ti delivers an incredible gaming experience today and far into the future.
It benefits from hand-chosen cores to deliver clock speeds that are streets ahead. Respectively, the cards speeds along at 1050MHz and 1072MHz (boosted) - that's an incredible 50MHz and 144MHz faster than reference designs.
For serious games-players this means a significant performance boost of up to 13% for super-smooth frame rates that refuse to stutter. With up to 4GB of high-speed DDR5 video memory on board the Matrix GTX780 Ti enables gamers to enjoy very high resolutions and detail levels.
This new ROG Matrix series card is brimming with advanced and exclusive hardware and software features designed to make overclocking as simple and safe as possible.
Memory Defroster is a brand-new feature that's designed to excite extreme overclockers. This clever technology quickly defrosts the graphics card's memory during below-zero overclocking to ensure sustained stability. Extreme overclockers will also appreciate the Matrix series' liquid-nitrogen (LN2) jumper switch, as it enables even more overvolting options - allowing the most adventurous users to unleash maximum greater power from their graphics cards.
The ROG Matrix series' Safe Mode allows users to overclock with complete confidence, as a single button push will restore default BIOS settings instantly.
To support stable overclocking, this card is also equipped with exclusive DIGI+ voltage-regulator modules (VRMs) with Super Alloy Power technology. The DIGI+ VRM delivers 14-phase power and digital voltage regulation, while Super Alloy Power's Japanese-made 10k black-metallic capacitors, 14 ultra-high-amperage full-molded chokes and extremely-efficient MOSFETs all withstand much greater stress and heat due to the application of specially-formulated materials.
The combination DIGI+ VRM and super-strength Super Alloy Power components means that the Matrix GTX780 Ti is forged for high-load performance and extreme overclocking without annoying whines and buzzes noises - so hardcore overclockers can enjoy plenty of headroom for experimental performance tuning without creating gameplay distractions.
ROG Matrix GTX780 Ti stays ultra-cool at all times, thanks some highly advanced and unique technologies - DirectCU II and CoolTech fan technology.
DirectCU is an innovative thermal technology that's exclusive to ASUS. It puts highly-conductive 10mm copper cooling pipes in direct contact with a card's GPU, so heat is dissipated quickly and with extreme efficiency. As well, the new ROG Matrix series introduces a new heat-sink that's finished in a stunning matt black, so the cards look as great as they're kept cool.
This card also features CoolTech fan technology. The CoolTech fan employs a hybrid blade and bearing design, with inner radial blower and outer flower-type blades to provide multi-directional airflow that accelerates heat removal to ensure high-end graphics performance that's highly stable. The fan's ramp is carefully tuned to ensure minimal noise.
For a final dash of style that's loaded with substance, ROG Matrix even features a gorgeous color-coded LED: this shines brightly and changes shade to reflect the GPU's load level, providing a useful visual guide for both casual and hardcore gamers.
The new ROG Matrix card includes GPU Tweak, an easy-to-use utility that gives users intuitive control over GPU and video-memory clock speeds and voltages, cooling-fan speeds and power-consumption thresholds, so they can overclock easily and with high confidence.
The exclusive ROG edition of GPU Tweak adds detailed GPU load-line calibration and VRM-frequency tuning, allowing incredibly fine control over multiple parameters for maximum overclocking and the potential to break world records.
As well, the GPU Tweak Streaming tool lets users share on-screen action over the internet in real time - so others can watch live as games are played. It's even possible to add a title to the streaming window along with scrolling text, pictures and webcam images.
Specification:-
- GeForce GTX 780Ti
- GPU: GeForce GTX 780Ti (GK110)
- Core Base Clock: 1000MHz
- Core Boost Clock: 1072MHz
- Memory Clock: 7000MHz
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£539.99] Inc. VAT
Only £499.99 inc VAT.
ORDER NOW
Kingston HyperX 8GB (2x4GB) PC3-14900C9 1866MHz Dual Channel Kit - Black/Gold (HX18C9BGK2/8-OC) **I52 PROMO** @ £49.99 inc VAT
This exclusive and special edition HyperX was designed by OcUK and manufacturered by Kingston. The results are memory modules that look absolutely stunning, give superb performance and efficiency but come with the re-assurance of Kingston build quality, reliability and lifetime warranty.
Tested in all Intel chipset platforms and compatible with AMD, this memory looks absolutely stunning in the latest motherboards from MSI, Gigabyte and Asus. For those who are OcUK fans this memory also has our logo printed on it, see the image gallery for pictures of this as we also build our very own in house systems using this memory.
Features:-
- Exclusive heatspreader designed by OcUK and built by Kingston
- Performance & Efficiency guaranteed
- Lifetime warranty
- Used by OcUK ourselves for our system production
- Black PCB
- XMP Profiles
Specification:-
- Capacity 8GB (2x4GB)
- Speed: 1866MHz
- CAS Latency: 9-11-9-24
- 1.5V-1.65V operating voltages enable stable overclocking
- Compatible with Intel XMP auto-overclocking function
- Designed to work with Intel & AMD Chipsets
- Dynamic black design and sharp edge accents
- 100-percent factory tested
- Lifetime Warranty
Was [£65.99] Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
Kingston HyperX Beast 16GB (2x8GB) PC3-19200C11 2400MHz Dual Channel Kit (KHX24C11T3K2/16X) @ £119.99 inc VAT
Unleash the Beast on your system. The vicious HyperX® Beast features a dynamic new heatspreader to maximize thermal dissipation for increased reliability. Plus it looks really cool and enhances any system. It’s Intel XMP ready so higher-performing frequencies, timings and voltages are just a few clicks away. The Beast gets along well with third-generation Intel Core i5 and i7 processors and the latest AMD performance and gaming processors. Put the Beast in your corner and crush your opponents — or just conquer your challenging workload.
Features:-
- Capacity 16GB (2x8GB)
- Speed: 2400MHz
- CAS Latency: 11-13-13-31
- 1.55V-1.65V operating voltages enable stable overclocking
- Designed to work with P55, H67, P67, Z68, H61 (AG), X79 and Z77 Intel chipsets; as well as A75, A87, - A88, A89, A78 and E35 (Fusion) AMD chipsets
- Lifetime Warranty
Was [£139.99] Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Kingston HyperX Beast 8GB (2x4GB) PC3-19200C11 2400MHz Dual Channel Kit (KHX24C11T3K2/8X) @ £59.99 inc VAT
Features:-
- Speed: 2400MHz
- Lifetime Warranty
Was [£79.99] Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Asus Radeon R9 290X DirectCU II OC 4096MB GDDR5 PCI-Express Graphics Card @ £359.99 inc VAT
The new card benefits from exclusive ASUS GPU Tweak, an easy-to-use tuning tool for instant performance boosts, 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions, and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and bring in-game audio to life with more accurate environmental sounds.
R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games and includes a free full game - the brilliant Battlefield 4™ from EA Digital Illusions Creative Entertainment™ (DICE).
The new ASUS R9 290X has a unique advantage in the shape of GPU Tweak, an exclusive ASUS tool that helps users to squeeze every last drop of performance out of the Radeon R9 290X GPU. This includes the ability to control finely GPU and video-memory clock speeds and voltages, cooling-fan speeds and power-consumption thresholds - so overclocking is both made easy and can be carried out with high confidence.
R9 290X is equipped with 4GB of high-speed GDDR5 memory, allowing gamers to push their favorite titles much further by upping in-game visuals to maximum resolutions. The new card also includes AMD Eyefinity technology to broaden the gaming landscape, so gamers can expand the playing field across up to six independent displays, via DisplayPort or DVI.
Specification:-
- GPU: Hawaii XT
- Litecoin Hash Rate: 850-1000
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1050MHz
- Memory Speed: 5400Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- PCI-Express X16 lane required
- 600W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 3yr
Was [£399.95] Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 290 PCS+ OC 4096MB GDDR5 PCI-Express Graphics Card with FREE AMD 8GB 2400MHz Memory Kit @ £299.99 inc VAT
PCS+ Version features Powercolor's amazing tri-fan cooler, for much lower noise levels whilst offering superior cooling. Along with a great overclock out the box, this card runs at 1040MHz core and 5400MHz memory.
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:-
- Radeon R9 290
- GPU: Hawaii Pro
- Litecoin Hash Rate: 800-950
- Stream Processors: 2560
- Core Speed: 1040MHz
- Cooling: 2-Slot Blower Fan
- 750W or greater PSU required
- Warranty: 2yr
Only £299.99 inc VAT - WITH FREE 8GB 2400MHz Memory Kit worth £89.99
ORDER NOW
Powercolor Radeon R9 290X PCS+ OC 4096MB GDDR5 PCI-Express Graphics Card with FREE AMD 8GB 2400MHz Memory Kit @ £359.99 inc VAT
PCS+ Version features Powercolor's amazing tri-fan cooler, for much lower noise levels whilst offering superior cooling. Along with a great overclock out the box, this card runs at 1050MHz core and 5400MHz memory.
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Fan Speed: 20% - 40% (Quiet Mode) & 20%-55% (Uber Mode)
- Comes with BF4 Voucher included in the box
- Warranty: 2yr
Only £359.99 inc VAT - WITH FREE 8GB 2400MHz Memory Kit worth £89.99
ORDER NOW
XFX Radeon R9 290 DD Black Edition 4096MB GDDR5 PCI-Express Graphics Card (R9-290A-EDBD) with FREE Kingston 60GB SSD @ £289.99 inc VAT
OcUK has negotiated special RMA terms with XFX which allows OcUK to express RMA any XFX item purchased from ourselves within 48 hours. Also exclusive to OcUK we allow the removal of the stock cooler for those wishing to water-cool their XFX product or change the cooler.
Specification:-
- GPU: Hawaii Pro
- ROPS: 64
- Memory Speed: 5000Mhz
- Card Dimension (cm) : 29.5 x 14.3 x 4.2
- Card Dimension (inch) : 11.61 x 5.63 x 1.65
- Warranty: 2yr
Only £289.99 inc VAT - WITH FREE 60GB SSD
ORDER NOW
XFX Radeon R9 290X DD Black Edition 4096MB GDDR5 PCI-Express Graphics Card (R9-290X-EDBD) with FREE Kingston 60GB SSD @ £379.99 inc VAT
For gamers who demand the very best, AMD Radeon™ R9 290X graphics shatters ordinary GPU performance. Groundbreaking GCN Architecture pushes your performance to insane levels while AMD TrueAudio technology and ultra-resolution gaming take you even deeper into the action.
XFX's exclusive Black Edition graphics card are the most rigorously tested graphics card. They are pre-overclocked to the maximum core clock achievable and come from the highest quality yield GPUs which make up the top 1% of those produced in the world. In addition, we pair it with the highest quality components to ensure there are no bottle necks so you can be certain you are getting the best graphics card possible on the market today.
XFX's exclusive ghost thermal 2.0 design creates a floating heatsink with open airflow between the PCB and the cover so that air can quickly ventilate off the card while simultaneously cooling the core process and the components. We've also made major advances from our first generation which includes a heat tested light weight plastic to create an overall lighter thermal which reduces the physical strain on your gpu.
XFX's exclusive dual fan double dissipation design utilizes two larger fans which run at slower RPM than comparable single fan soltuions which must run at much higer RPMs just to barely achieve the same cooling needs. Because of this design, XFX is able to achieve up to 13db lower noise than the competitor while simultaneously increasing the overall cooling by 7°C.
Specification:-
- GPU: Hawaii Pro
- ROPS: 64
- Warranty: 2yr
Only £379.99 inc VAT - WITH FREE 60GB SSD
ORDER NOW
XFX Radeon R9 280 DD Edition 3072MB GDDR5 PCI-Express Graphics Card (R9-280A-TDBD) with FREE Kingston 60GB SSD @ £169.99 inc VAT
XFX R9 280 has the performance to power the latest games with ease but at a very aggressive price point making it incredible value for money.
Specification:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Core Clock Speed: 933MHz
- Shader Architecture: GCN
- Stream Processors: 1792 ALU
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 5000MHz
- Load / Idle Board Power: <300W / <3W
- Display Outputs: 2x DVI + 1x DP + 1x HDMI
- Power: 250W TDP
- 2yr Warranty
Only £169.99 inc VAT - WITH FREE 60GB SSD
ORDER NOW
XFX Radeon R9 280X DD Black Edition 3072MB GDDR5 PCI-Express Graphics Card (R9-280X-TDBD) with FREE Kingston 60GB SSD @ £221.99 inc VAT
XFX R9 280X has the performance to power the latest games with ease but at a very aggressive price point making it incredible value for money.
Specification:-
- Core Clock Speed: 1080MHz
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Memory Width / Speed: 384 bit / 6200MHz
- Power: 250W TDP
- 2yr Warranty
Only £221.99 inc VAT - WITH FREE 60GB SSD
ORDER NOW
Powercolor Radeon R9 270 TurboDUO 2048MB GDDR5 PCI-Express Graphics Card @ £99.95 inc VAT
The AMD Radeon R9 270 GPU continues AMD’s tradition of delivering world-class performance, features and multi-monitor support at an incredible value,” said Matt Skynner, corporate vice president and general manager, Graphics Business Unit, AMD. “With Mantle, exceptional performance and ultimate gaming experiences are synonymous with AMD Radeon R7 and R9 Series graphics cards. Once again, AMD proves that Radeon™ is gaming.”
Specification:-
- Litecoin Hash Rate: 350-500
- Core Clock Speed: 930MHz
- Core Boost Speed: 955MHz
- Stream Processors: 1280
- Frame Buffer / Memory: 2GB GDDR5
- Memory Width / Speed: 256 bit / 5600MHz
- Power Connectors: 6-pin + 6-pin
- Display Outputs: 1x DVI + 1x DP + 1x HDMI
- Power: 180W TDP
- 2yr Warranty
Was [£109.99] Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
Powercolor Radeon R9 280 TurboDUO 3072MB GDDR5 PCI-Express Graphics Card @ £149.99 inc VAT
owercolor R9 280X has the performance to power the latest games with ease but at a very aggressive price point making it incredible value for money.
Equipped with TurboDUO near silent cooling solution meaning you can game in near silence whilst keeping the card nice and cool.
Features:-
- Multi Phase Design: 8 Power Phases for improved OC ability
- Digital PWM
- Ferrite Core Choke: Decreases ripple to deliver more stable voltage
- DirectFET
- Patent GSG- Shape Heat Pipes Design: Reduces temperatures by upto 17% and noise reduction of upto 19%
- Pure Copper Base
- Backplate included
Specification:-
- Litecoin Hash Rate: 550-750
- Hugely overclockable
- Core Clock Speed: 855MHz
- Boost Clock Speed: 960MHz
- Power: 250W TDP
- 2yr Warranty
Was [£155.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 280X TurboDUO 3072MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
Powercolor R9 280X has the performance to power the latest games with ease but at a very aggressive price point making it incredible value for money.
Features:-
- Digital PWM
- DirectFET
- Pure Copper Base
Specification:-
- Core Clock Speed: 880MHz
- Boost Clock Speed: 1030MHz
- Memory Width / Speed: 384 bit / 6000MHz
- Power: 250W TDP
- 2yr Warranty
Only £199.99 inc VAT.
ORDER NOW
NVIDIA Shield 8" Tegra K1 2.20GHz, 2GB DDR3, 16GB Storage, 1920x1200 IPS WiFi Tablet - Android 4.40 KitKat @ £239.99 inc VAT
Only £239.99 inc VAT - IN STOCK!!
ORDER NOW
ASUS ROG G750JZ-T4056H - 17.3" FHD LED / i7-4700HQ / NVIDIA GeForce GTX880M (4G DDR5) / 16G / 1TB + 256GB SSD / BD Read / Win 8.1 64B / AGN (Killer WAN) / 8 Cell @ £1,499.99 inc VAT
Break the Barriers - Experience the overclockable 17" gaming laptop
Ergonomic Design
G750 is even slimmer and more gamer-centric than previous G Series notebooks, which is saying a lot. It meets your gaming needs as the ultimate weapon in any gameplay genre, making you a better gamer and a mightier ally to your teammates. Once more, the eye-catching design draws inspiration from stealth fighters, presenting an ergonomically-inclined surface for greater comfort during long gaming sessions. To better keep in touch with your co-op partners and everyone else, there's an HD camera, while a range of exclusive accessories complete your gaming experiences for more thrills at home and away.
Extreme Performance
Enjoy desktop-level performance with a pumped 4th-generation Intel® Core™ i7-4700 processor and gaming-grade NVIDIA® GeForce® GTX 880M graphics, with ASUS TurboMaster technology for the ultimate gaming experience!
Gamer-Centric Interfaces
Great gaming demands the fastest interfaces and the best displays, and G750 has been built to deliver nothing but the best. Its onboard Intel® Thunderbolt™ technology provides ultra-fast graphics and data transmission via a single connection, while the Killer Wireless-N 1202 chip delivers blazingly-fast and stable wireless networking. G750 supports next-generation 4K Ultra High Definition (4K/UDH) displays for incredible levels of detail, and with ASUS Trinity display technology you can connect up to three displays simultaneously for a truly incredible experience.
Majestic Sound
Where many gaming notebooks treat sound as an afterthought, G750 puts it front and center. It features exclusive ASUS SonicMaster and ROG AudioWizard, designed by a dedicated team of audio engineers as a careful balance of hardware and software towards the best notebook sound. Sure, with G750 your games look their best, but they also sound fantastic. Every effect and note comes out with increased power, range, and clarity. This is more than enjoyment: as any gamer knows, sound is critical to success play, giving you the edge with sonic awareness and positioning. G750 integrates the latest design, with features specifically created for gaming and gamers.
Incredible Cloud
ASUS cloud services provide the most complete platform for online living that's accessible anywhere from a host of devices. With ASUS WebStorage, convenience is the main priority, offering you easy storage, sharing, and syncing of everything from business presentations to photo albums and favorite multimedia content. Each ASUS ROG G750 comes with free WebStorage space, and features the MyBitCast app so you can easily sync your content to multiple devices and accounts simultaneously.
Specification:
- Display: 17.3" LED-backlit TFT LCD Display resolution: FHD 1920x1080 / 16:9 Display type: (Typical 220-nit) , 8ms response time NTSC:60%
- Processor Type: Intel® Quad-Core Core™ i7-4700HQ Processor (6M Cache, 2.40 GHz, up to 3.40 GHz)
- Processor Cores: Quad Core
- Processor Clock Speed: 2.40GHz (3.40GHz Turbo Mode)
- Hard Drive Supplied: 1 x 1000GB
- Hard Drive Size: 1000GB
- Solid State Drive: 256GB SSD x1
- Hard Drive Speed: 5400RPM
- Memory Supplied: 2 x 8GB
- Memory Size: 16GB
- Memory Type: DDR3L
- Memory Speed: 1600
- Memory Socket: 2 x SO-DIMM
- Max. Memory Support: 32GB
- Operating System: Windows 8.1 (64bit)
- Graphics Chipset: NVIDIA GeForce GTX880M
- Graphics Memory: 4GB GDDR 5
- Chipset: Mobile Intel® HM87 Express Chipsets
- Microphone: Built-in array microphone
- LAN: 10/100/1000Mbps
- Wireless: 802.11agn
- Bluetooth: 4.0 (dual band)
- USB 3.0 Port(s): 4
- HDMI Port(s): 1
- VGA Port(s): 1
- Microphone Jack(s): 1
- Headphone Jack(s): 1
- LAN Port(s): 1
- Card Reader: SD, MMC
- Keyboard: Illuminated Chiclet Keyboard
- Dimension: 41.0(W) x 31.8(D) x 1.80 ~ 5.00 (H) cm
- Product Weight (g): 4.00 KG (Without Battery) - 4.50 KG (with 8 cell battery)
- HD Webcam
- Warranty: 2 Years
Was [£1799.99] Inc. VAT
Only £1,499.99 inc VAT.
ORDER NOW
Aorus X7 v2-CF1 17.3" LED TFT, Intel Core i7-4860HQ, 16GB DDR3, 3x128 SSD RAID, 1TB HDD, Dual NVIDIA GTX 860M SLI - Windows 8.1 @ £1,745.99 inc VAT
"AORUS X7 delivers unlimited gaming experience without the cost of mobility and practicability. AORUS products are crafted and engineered from the ground up to signify the timeless legacy of gaming, in which a spirit of ancient gamers shining above and watching over all gamers despite the time shift.
AORUS X7 features NVIDIA® GeForce® GTX 860M dual graphics and the 4th gen. Intel® Core™ i7 processor delivers immense performance, in a slate-like chassis. The exclusive Thermal+ Technology achieves class-leading cooling effect and unparalleled reliability and stability. Its understated design yet dynamic outlook marks this state-of-the-art gaming gear an effortlessly thrilling, technically dominant and precisely tuned gadget. AORUS’ exclusive software and top-notch components altogether compose an ultimate gaming platform with incredible portability. Though uncompromised gaming pleasure is aimed as the first priority, X7 still makes a perfect companion for graphic computing and daily use.
Discover X7: a great combination of power and agility."
Features:-
- Extremely powerful Dual NVIDIA GTX 860M 8GB GDDR5 Graphics
- Vivid Full HD screen with wide colour gamut display
- AORUS Thermal+*Technology - dissipates heat effectively and provides constant stability!
- Superior Anti-Ghost Backlit Keyboard - Never Miss a Shot!
- Features NVIDIA 3D Vision Surround - Supports up to 3 displays for perfect gaming vision!
- AORUS Exclusive programmable Macro Hub simplifies routine operations
- Super Thin at only 22.9mm and extremely Lightweight at only 2.9Kgs
Specification:-
- Screen Size: 17.3"
- Screen Type: LCD
- Backlight: LED
- Screen Resolution: 1920x1080 Full HD
- Processor: Intel Core i7-4860HQ, 2.4~3.6GHz
- Processor Clock Speed: 2.4GHz ~ 3.6GHz (Overclock)
- Graphics Chipset: 2 x NVIDIA GTX 860M SLI GDDR5
- Graphics Memory: 4GB each (8GB Total)
- Hard Drive: 1000GB, 7200rpm
- SSD Drive: 3 x 128GB (RAID 0)
- Memory Supplied: 2 x 8GB 1866MHz
- Memory Size: 16GB 1866MHz
- Memory Socket: 4 x SO-DIMM 1866MHz
- Audio: 2 x Speakers, 2 x Woofers, Microphone, AORUS Acoustic+ Technology
- LAN: Killer LAN Chip E2201
- Wireless LAN: 802.11ac
- Bluetooth Version: v4.0
- Webcam: 1.0 Megapixel
- USB 3.0 Port(s): 3
- USB 2.0 Port(s): 2
- HDMI Port(s): 1
- Mini Display Port(s): 1
- Surround Port(s): 1
- Card Reader: SD
- Security: Kensington Lock
- Battery: Li Polymer, 73.26Wh
- Dimension: 392 x 263 x 22.9mm
- Weight: 2.99Kgs
- Warranty: 2 Years
Only £1,745.99 inc VAT.
ORDER NOW
BitFenix Fury 550W Gold Modular Power Supply - Alchemy Cables (BFP-FUR-550G-KSXK-RP) @ £79.99 inc VAT
For a long time, the power supply is one part of the PC that users prefer to remain unseen. These dull, lifeless boxes were made to perform in the background, away from sight. Challenging the status quo, BitFenix set out to make a power supply that not only delivered on a performance level, but also utilized enough design elements to let it stand out in a system build. To that end, BitFenix announces the Fury Power Supply Series. Featuring top quality components like all Japanese capacitors, a killer design aesthetic, and top-notch efficiency, Fury is set to become the new gold standard in semi-modular power supply units.
Starting with the chassis, Fury brings a bold yet sophisticated design to the realm of power supplies. Both top and bottom are adorned with a stamped BitFenix logo, along with a custom aluminum ring accent that exudes an aggressive look no matter which direction you install it. Combined with a quality matte powder-coat finish, Fury is the first PC power supply that's designed to enhance the look of your system.
After taking the modding world by storm with the Alchemy lineup of sleeved cable extensions, BitFenix has brought its one of a kind Nanosleeve braiding to the Fury Power Supply. Each cable that comes with Fury is sleeved with Nanosleeve braiding for excellent flexibility and unsurpassed aesthetics. With Fury, modders will spare their warranties while saving hours of time sleeving their own PSU cables. Best of all, the semi-modular design allows builders to only use the cables they need, reducing cable clutter and improving airflow inside the system. For the boutique modded look with zero effort, look no further than BitFenix Fury.
All of this power is harnessed via several key components and technologies that make Fury a power supply users can rely on day in and day out. To ensure clean output and long life, Fury employs a design that utilizes all Japanese capacitors. Renowned for their quality and longevity, all Japanese capacitors puts Fury in a class above other PSU designs. A 135mm fluid dynamic bearing fan not only helps keep temperatures under control, but does so with minimal noise. Finally, Fury also comes equipped with BitShield Six-Point Protection, a series of safeguards that prevent damage to the PC caused by electrical anomalies, including under voltage, over voltage, short circuit and more. All of this is backed by a five-year warranty so users can use Fury with confidence.
Available in 550W, 650W, and 750W models, BitFenix Fury delivers a trifecta of performance, reliability and aesthetics perfect for today's high octane PC builds.
Specification:-
- Built by FSP, Designed by BitFenix
- Dimensions (WxHxD): 150mm x 86mm x 160mm
- MTBF: 100,000 hours
- Efficiency Rating: 80Plus Gold
- PF Correction: Active
- Operating Temp. 0 - 40°C
- Protection Features: Over Voltage / Under Voltage / Over Current / Short Circuit / Over Temperature / Over Power
- Safety Approvals: CB / TUV / ULOR CUL / BSMI
- 3.3v: 24A
- 5v: 24A
- 12v: 42A
- Total Power: 550W
- 1x 8-pin CPU Cable (8+4+4)
- 4x 8-pin VGA Cable (6+2)
- 3x SATA Cable (quad, dual, dual)
- 1x Molex Cable (triple)
- 1x SATA + Molex (1+1)
- 1x Floppy Adapter
- 4x Standard Screws
- Warranty: 5yr
Was [£89.99] Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
BitFenix Fury 650W Gold Modular Power Supply - Alchemy Cables (BFP-FUR-650G-KSXK-RP) @ £89.99 inc VAT
Specification:-
- 3.3v: 26A
- 5v: 26A
- 12v: 50A
- Total Power: 650W
- 1x Floppy Adapter
- Warranty: 5yr
Was [£99.95] Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
BitFenix Fury 750W Gold Modular Power Supply - Alchemy Cables (BFP-FUR-750G-KSXK-RP) @ £99.95 inc VAT
Specification:-
- 3.3v: 30A
- 5v: 30A
- 12v: 60A
- Total Power: 750W
- 1x Floppy Adapter
- Warranty: 5yr
ORDER NOW
Corsair HX750i Full Modular Digital Power Supply (CP-9020072-UK) @ £113.99 inc VAT
HXi Series power supplies give you extremely tight voltage control, virtually silent operation, and a fully modular cable set. With all Japanese 105°C capacitors, they’re a great choice for high performance PCs where reliability is essential. 80 PLUS Platinum efficiency reduces operating cost and excess heat, and together with Zero RPM Fan Mode technology, gives you virtually silent operation.
With Corsair Link Digital support, you can monitor power supply performance, toggle single rail or multi rail mode, and control fan speed directly from your desktop. And, the fully modular, low profile cable set makes builds and upgrades easy, with clean, great-looking results.
80 PLUS Platinum efficiency and Zero RPM Fan Mode mean that at low to medium loads, the fan doesn’t spin at all. And when you do push the HXi hard, the thermally controlled fan spins only as fast as it needs to.
But that’s not all. It’s quieter than most PSUs when the fan’s not spinning, too. The HXi is built with capacitors and other internal components specially selected to reduce coil whine and other electronic noise.
Connect the included cable to a motherboard USB header and download the free Corsair Link Dashboard application for Windows and you can monitor performance and efficiency, toggle single rail or multi rail mode, and control fan speed directly from your desktop.
The fully modular, low-profile cable set allows for quick and easy installation and great-looking builds. The fan self-test switch lets you quickly confirm operation before you even attach cables to your motherboard.
Features:-
- Corsair Link™ Integration for monitoring performance and adjustment of fan speed and multi-rail/single rail mode.
- 80 PLUS® Platinum efficiency, delivering 92% energy efficiency at real world load conditions.
- ZeroRPM mode for fanless operation at low loads and outstanding noise reduction.
- 140mm thermally controlled fluid dynamic bearing fan spins up as needed.
- Fully Modular low profile cables for easy installation, less clutter, and helps maximize airflow through your computer’s chassis.
- Engineered to meet maximum power output at a server-grade 50C temperature rating.
- Fan self-test switch to determine fan functionality even before installation.
- Over-voltage protection, under-voltage protection, and short circuit protection, over power protection, over temperature protection provide maximum safety to your critical system components.
- Safety and Agency Approvals: FCC, ICES, CE, UL / CUL, CSA, C-Tick/RCM, TUV, CB, CU, KC Mark, RoHS, WEEE, RoHS (China), REACH.
Specification:-
- 80 Plus Platinum
- Power: 750 Watts
- Fanless mode: Yes
- Fan bearing technology: Fluid Dynamic Bearing
- Fan size (mm): 140mm
- C-Link Digital: Yes
- Continuous output rated temperature (°C): 50°C
- ATX Connector: 150mm x 86mm x 180mm
- Modular: Yes
- Sleeved cables: Low-Profile, All Black
- ATX Connector: 1
- EPS Connector: 2
- Floppy Connector: 2
- Four Pin Peripheral Connector: 8
- PCI Connector: 6
- SATA Connector: 12
Was [£119.99] Inc. VAT
Only £113.99 inc VAT.
ORDER NOW
Corsair HX850i Full Modular Digital Power Supply (CP-9020073-UK) @ £125.99 inc VAT
Features:-
Specification:-
- 80 Plus Platinum
- Power: 850 Watts
- Fanless mode: Yes
- Modular: Yes
- ATX Connector: 1
- EPS Connector: 2
- Four Pin Peripheral Connector: 12
- PCI Connector: 6
Was [£129.95] Inc. VAT
Only £125.99 inc VAT.
ORDER NOW
Corsair HX1000i Full Modular Digital Power Supply (CP-9020074-UK) @ £149.99 inc VAT
Features:-
Specification:-
- 80 Plus Platinum
- Power: 1000 Watts
- Fanless mode: Yes
- Modular: Yes
- ATX Connector: 1
- EPS Connector: 2
- PCI Connector: 8
ORDER NOW
SuperFlower Leadex GOLD 1300W Fully Modular "80 Plus Gold" Power Supply - Black @ £139.99 inc VAT
Leadex series PSU are 80+ Gold certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Ledex series PSU provides high efficiency & stable power output and come with a 14cm two-way thermal control intelligent cooling fan to ensure your professional PC system will work under heavy load, also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
Features:-
- 100% Full Modular Cabling Design For Easy Cable Management
- 80 PLUS ® Gold Certified, 91.09% 91.75% 89.25% Efficiency At 20% 50% 100% Rated Load
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED
- More than 2,000 times On/Off test
- Unleaded Green Materials with RoHS/WEEE Compliance
- Perfect For Professional & High Performance Gaming System
Specification:-
- Type: ATX
- Maximum Power: 1300W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Modular Cable Yes 100% modular cable design
- Input Voltage Full Ranage - 100V~240V
- Input Frequency Range 50 ± 3 Hz / 60 ± 3 Hz
- Output +3.3V@24A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
- Protection OVP?OCP?OPP?SCP?UVP
- Dimension 200mm(L) x 150mm(W) x 86mm(H)
- 1x 20+4-Pin ATX12V/EPS12V
- 1x 8-Pin EPS12V
- 1x 4+4-Pin ATX12V/EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
- Review: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=367
Was [£149.99] Inc. VAT
Only £139.99 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 1000W Fully Modular "80 Plus Gold" Power Supply - Black @ £119.99 inc VAT
Features:-
- 80 PLUS ® Gold Certified, 90.43% 92.03% 90.27% Efficiency At 20% 50% 100% Rated Load
Speciication:-
- Type: ATX
- Maximum Power: 1000W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Modular Cable: Yes 100% modular cable design
- 1x 8-Pin EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
ORDER NOW
SuperFlower Leadex GOLD 850W Fully Modular "80 Plus Gold" Power Supply - Black @ £95.99 inc VAT
Features:-
Speciication:-
- Type: ATX
- Maximum Power: 850W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- 1x 8-Pin EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £95.99 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 750W Fully Modular "80 Plus Gold" Power Supply - Black @ £79.99 inc VAT
Features:-
Speciication:-
- Type: ATX
- Maximum Power: 750W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- 1x 8-Pin EPS12V
- 4x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
ORDER NOW
SuperFlower Leadex GOLD 650W Fully Modular "80 Plus Gold" Power Supply - Black @ £74.99 inc VAT
Features:-
Speciication:-
- Type: ATX
- Maximum Power: 650W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Output +3.3V@22A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
- 1x 8-Pin EPS12V
- 4x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £74.99 inc VAT.
ORDER NOW
Thrustmaster T500 RS Simulator Racing Wheel for PS3 & PC Licensed for Gran Turismo 6 @ £299.99 inc VAT
H.E.A.R.T. HALLEFFECT ACCURATE TECHNOLOGY™” is the name of the new technology developed by Thrustmaster to reproduce movements made on a product in games. It relies on magnetic – and not mechanical – 3D (HallEffect) sensors, placed in different locations according to the product in question. The precision made possible by the use of this technology is significantly higher than that provided by standard technologies. Another advantage of this system: by eliminating all friction, it guarantees zero mechanical wear, for permanent precision that won’t decrease over time. The level of precision is also enhanced by the absence of any dead zones: even the slightest movement made by the player results in a reaction. Actions in games are therefore more linear, smoother and without any untimely jolts.
- Authentic wheel: 30cm (12”) in diameter with brushed metal central spokes
- Authentic sequential gearshift levers: crafted of brushed metal, attached to the base (so they don’t move with the wheel)
- 17cm in height (for instant access along 1080°)
- Precision, Force Feedback & realistic angle of rotation
- New H.E.A.R.T Hall Effect AccuRate Technology™ on the wheel’s steering:
- Ultra-precise wheel, with 16-bit resolution (65536 values on the steering)!
- Precision that won’t decrease over time (contactless magnetic sensor)
- Force Feedback with industrial motor (Torque 150mNm, 3000rpm, 65W, Ø 52mm/2”)
- Super-powerful, quick responding Force Feedback mechanism
- Rigid motorized stopper, no matter what angle of rotation you select
- Mechanism with large dual belts (fluid and smooth action)
- Angle of rotation adjustable up to 1080° (3 full turns)!
- Realistic pedal set
- Unique design with your choice of 2 positions:
- Floor-mounted position (F1-style)
- Suspended position (GT-style)
- 100% metal, for optimal stability, weight (more than 7 kgs) and resistance
- 3 100% adjustable pedals (spacing between the pedals/height)
- Brake pedal with reinforced and adjustable resistance (included and removable “Realistic Brake” mod)
- Included metal footrest with non-slip grating texture
Was [£329.99] Inc. VAT
Only £299.99 inc VAT - WITH FREE GRID AUTO SPORT!
ORDER NOW
Asus VS228DE 22" Widescreen LED Monitor - Black @ £77.99 inc VAT
VS228DE Full HD LED monitor, with 50,000,000:1 high contrast ratio, is optimized for the finest image and colour quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
Key Features:-
- True-to-life Pictures Powered by LED
- Full HD 1080p Support
- Versatile viewing positions with Smart View Technology
- Aspect Control function
- Splendid Video Intelligence Technology
Specifications:-
- Screen Size: 21.5"
- Screen Type: LCD
- Backlight: LED
- Aspect Ratio: 16:9
- Recommend Resolution: 1920 x 1080
- Screen Features: Full HD
- Colours: 16.7 Million
- Pixel Pitch: 0.248mm
- Horizontal Frequency Range: 30kHz - 80kHz
- Vertical Frequency Range: 55Hz - 75Hz
- Response Time: 5ms
- Contrast Ratio: 600:1
- Dynamic Contrast Ratio: 50,000,000:1
- Brightness: 200 cd/m²
- Max. Resolution: 1920 x 1080
- Horizontal Viewing Angle: 90°
- Vertical Viewing Angle: 65°
- Tilt Angle: -5°/20°
- VGA Port(s): 1
- Product Width: 556mm
- Product Height: 443mm
- Product Length: 130mm
- Input Power Source: Power Lead
- Normal Power Consumption: 21.1W
- Stand-by Power Consumption: 0.5W
- Wall Mount: VESA 100mm x 100mm
- Warranty: 3yr
Only £77.99 inc VAT.
ORDER NOW
Asus VS229HA 22" Widescreen MVA LED Monitor - Black @ £99.95 inc VAT
Delicate touches make a monitor truly great, VS229HA Full HD LED monitor, with 80,000,000:1 high contrast ratio and full HDMI, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port.
VS229HA adopts 178°(H) / 178°(V) ultra wide viewing angle panel that eliminates color shift on your screen no matter where and how you look at it. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
Specifications:-
- Screen Type: VA
- Backlight: LED
- Vertical Frequency Range: 56Hz - 76Hz
- Response Time: 5ms (GTG)
- Contrast Ratio: 1000:1
- Dynamic Contrast Ratio: 80,000,000:1
- Brightness: 250 cd/m²
- Horizontal Viewing Angle: 178°
- Vertical Viewing Angle: 178°
- VGA Port(s): 1
- DVI Port(s): 1
- HDMI Port(s): 1
- Warranty: 3yr
ORDER NOW
Samsung LS22C570HS 22" Widescreen LED Monitor - Glossy Black @ £99.95 inc VAT
Part of Samsung’s LED Monitor Series 5 range, the LS22C570HS is a slim 21.5” monitor with a modern, inspiring style. It has been packed full of technology to provide enhance functionality, giving you improved picture quality and a wide viewing angle.
Series 5 monitors feature Mega Dynamic Contrast Ratio, which delivers vast levels of colours to improve moving image quality, displaying blacks at their darkest and other colours at their brightest. This not only improves picture quality and increases vibrancy, but also helps to deliverer clearer picture clarity. A static contrast ratio of 1000:1 of ensures high quality still images and text.
A wide viewing angle of 178° horizontally and vertically gives you more options of where you can see the screen from without losing image definition. This ensures crisp, clear and perfect colours from almost any angle.
Resolution up to Full HD 1920x1080, ensures that high definition images and video will display in HD, while text looks sharp and well defined. A rapid response time of 5 milliseconds means this monitor can keep up with fast moving action, while the LS22C570HS can show up to 16.7 million colours, to give you the variety that you see in real life.
Samsung’s Magic Upscale technology improves image quality to give you enhanced picture quality, no matter what the resolution of the original image. It prevents image degradation when scaling up and presents brilliant, clean colours and sharp images.
Eco Saving mode will assist you in saving power and money. You can choose from three options (50%, 25% and Power Saving off) to help make power saving easy and tailor your monitor use to suit your needs.
HDMI and VGA inputs give you the ability to connect this monitor to a wide variety of devices, from desktop PCs and laptops to Blu-ray players and games consoles.
Specification:-
- Screen size: 21.5"
- Screen Type: VA Panel
- Resolution: 1920x1080
- Response time: 5ms
- Contrast ratio: Mega DCR (static 1000:1)
- Brightness 250cd/m²
- Viewing Angles: 178/178
- Connectivity: 1x HDMI, 1x VGA, Audio Out
- Speakers: NO
- Colours supported: 16.7 million
- Dimensions (monitor only): H311.91 x W507.4 x D99.82 mm
- Dimensions (monitor with stand): H407.6 x W507.4 x D189.9 mm
- Warranty: 2yr
ORDER NOW
AOC G2460PQU 24" Widescreen 144Hz 1ms Gaming LED Monitor - Gunmetal @ £179.99 inc VAT
This display will make any gaming enthusiast´s heart beat faster: the stylish g2460Pqu will impress you with crystal-clear pictures. Enjoy fast-paced action sequences from the latest games or movies – crisp and blur-free due to an ultra-fast response time of just one millisecond and a refresh rate of 144 Hz. The strong typical contrast (1000:1) and high brightness (350 cd/m²) provide brilliant images. This gamers´ dream-come-true sports numerous connectivity options, such as D-Sub, DVI Dual Link, HDMI, DisplayPort and an integrated USB hub. These enable you to comfortably plug in several devices at the same time and display hi-res content on the large 61 cm (24") screen. Also on board: an integrated USB hub with 4 ports, including a fast-charge USB port for mobile devices. In addition, the Full HD display is equipped with LED backlights, making it particularly economical despite its great performance.
Product Review
- Won Kitguru "Worth Buying" Award
- Full Review Here: http://www.kitguru.net/peripherals/monitors/zardon/aoc-g2460pqu-144hz-24-inch-monitor-review/
Specification:-
- Height Adjust Stand
- USB Hub
- Monitor Size: 24"
- Visible Screen Size: 61 cm
- Screen Format: 16:9
- Brightness: 350 cd/m² (typ)
- Contrast Ratio Dynamic: 80.000.000:1
- Contrast Ratio Typical: 1000:1
- Pixel / Dot / Pitch: 0.276 (H) x 0.276 (V)
- Display Area: 531.36 (H) x 298.89 (V)
- Viewing Angle: 170°/160° (CR 10)
- Response Time: Up to 1 ms GtG
- Maximum Resolution: 1920 x 1080@144 Hz (DVI Port)
- Recommend Resolution: 1920 x 1080@144 Hz
- Colors: 16.7 M
- HDCP compatible: yes
- Inputs: Analogue, DVI-D, HDMI & DisplayPort
- Dimensions (WxHxD): 565.4 x 393.6 (+130) x 244.58 mm
- Warranty: 3yr
Was [£199.99] Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
AOC G2460PG 24" Widescreen G-Sync 144Hz 1ms Gaming LED Monitor - Gunmetal @ £341.99 inc VAT
The AOC G2460PG display combines stylish design with high-performance features that will impress the most demanding gamers. From first-person shooters to high-speed racing games, you’ll never miss out on the action with 1 ms response time for blur-free images. This 24-inch display with Full HD resolution offers sharp, stunning picture quality with typical 1000:1 contrast ratios. The integrated DisplayPort connector and five USB hubs are ideal for hooking up a range of devices and peripherals, plus USB 3.0 technology offers super-speed charging and data transfer. The ergonomic stand offers hours of viewing or gaming comfort, allowing you to adjust the height, tilt and swivel, as well as pivot into portrait mode. No matter what you’re doing, smart energy-saving functions like W-LED backlighting help reduce your power consumption.
Specification:-
- NVIDIA G-Sync Technology
- Monitor Size: 24"
- Colors: 16.7 M
- Inputs: DisplayPort
- Warranty: 3yr
Was [£347.99] Inc. VAT
ORDER NOW
LG Flatron 34UM95-P 34" WideScreen Super-Wide LED Monitor @ £799.99 inc VAT
The UltraWide 21:9 aspect ratio makes movies and games more immersive than ever. Need to get some work done, too? All of that UltraWide real estate makes it easy to view multiple documents at the same time, so you don't need to flip back and forth between them.
The 3440X1440 UltraWide QHD display offers amazingly sharp picture quality. Its pixel area is about 1.8 times larger than an UltraWide Full HD 21:9 monitor, and about 2.4 times larger than a Full HD 16:9 monitor. It provides an efficient environment in using Microsoft Office programs showing 47 columns and 63 rows in excel.
sRGB is the standard color space of ideal color reproduction. So, with over 99% coverage of the sRGB spectrum, this LG monitor is a great solution for professional photographers, graphic designers or anyone looking for highly accurate color.
Multitasking doesn't have to mean shuffling back and forth between windows*. With a single click, the 4-Screen Split feature divides the screen into as many as four customizable segments, two-by-two. Now you can see four different windows at the same time.
The Dual Linkup feature allows two compatible portable devices--such as a computer, camera, phone, or Blu-ray player--to be connected to the monitor, and both can be viewed on the same screen simultaneously.
This monitor's Thunderbolt input/output port allows you to connect up to six compatible devices, moving data between them with incredible speed. The two channels of 10-gigabits-per-second throughput in both directions are up to 20X faster than USB 2.0. Thunderbolt is an exciting innovation for both expansion and premium video display.
The DisplayPort digital video interface is used to connect a high-performance video source to a high-resolution monitor. Thanks to its sophisticated design, a DisplayPort cable can also be used to carry audio, USB signals and other data as well.
LG’s LED backlighting delivers exceptional brightness and amazing image clarity. You'll see richer colors and deeper blacks too, and LEDs offer greater energy efficiency compared to conventional LCD monitors.
IPS (In-Plane Switching) technology enhances thA dynamic contrast ratio of 5,000,000:1 is your assurance of strong video performance, with deep blacks, bright whites and pleasing colors.e performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can now view the screen at virtually any angle.
Looking for the ultimate in fine-tuning for your LG monitor? This model is designed to work with compatible calibration devices* that take specific readings and guide you through precise adjustments of color, brightness and more.
Specification:-
- Screen Size Class (diagonal): 34"
- Panel Type: IPS
- Aspect Ratio: 21:9
- Resolution: 3440x1440
- Color Gamut (CIE1931): sRGB 99%
- Brightness (typical): 320 cd/m2
- Contrast Ratio(Original): 1000:1
- Viewing Angle (CR>10): 178/178
- Colour Depth (Num of Colours): 1.07B (8-Bit+FRC)
- Pixel Pitch (mm): 0.2325
- Surface Treatment: Anti-Glare 3H
- Connectivity: 2x HDMI, 1x DisplayPort & 2x ThunderBolt
- Warranty: 2yr
Only £799.99 inc VAT.
ORDER NOW
We are unbeatable on the above deals price/value wise, please do not miss out!! :)
Just to point out that although that 290 is a very nice card ...well apart from the " drop outs" in game and the fact that on the box there is a sticker for a BF4 " Full Game Download " ....but there is no download .
tried looking on the website of the gpu (not amd, sapphire or msi etc)? might be details there also you could email the company and see if they'll get you a code.
Some of these are incredibly pants. :p
£4 off of a £130 PSU
£6 off of a £350 Monitor
And the best one, £3.94 off of a £1750 laptop. :D
Why is there £300 off of an £1800 laptop, and less than £4 off of a £1750 one? :p
Some nice deals too. ;)
well i did get the games that came with the Gold Ticket from AMD ...which is what XFX's site claims is the only offer , this is what it says
" Your product is not eligible for any XFX game promotion at the moment. Please check with the place of purchase for promotions provided directly from AMD."
AMD ended BF4 end of March this year.
Are they cheaper elsewhere? If so I will undercut!
I'm not suggesting that the prices are bad, I'm just saying that the "deals" seem silly. They may as well not be deals at all. :D
I'm guessing it is an easy way to draw attention to them, because the base prices were good in the first place. :)
I'm guessing these prices are calculated from cost price to OcUK so don't fully expect to understand them guys! Unit prices in the retail channel frequently change and are probably calculated over a shipment rather than on individual items (except maybe the high value laptops)! A discount is a discount! A discount on an already discounted item might not sound much - but it just goes to show how close OcUK's prices are to cost anyway! ;)
But Gibbo the box in which the card came infers that if one registers one's card with XFX one then can download BF4 ...I was under the impression that the XFX Cards were a new product and had not been around since March
XFX obviously not changed packaging. As BF4 ended in March. AMD Gold replaced it.
I know it's not one of the products you were referring to, but any chance of a couple more quid off the HyperX Cloud? You've already knocked £10 off (thank you!) but a competitor is still £6 cheaper and in stock. I'll still be getting it from you (nobody else has the OcUK customer service) but those extra few quid are the difference between getting the PSU I want now or after payday next week.
Pretty please? :)
Hi there
Specification:-
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 3yr
ORDER SOON
Do you get a pair of Asus headphones with this card as well?
Pretty please? :)
Done we are now £53.99 inc. vat, wait for website to update!
