Hoping there's an easy solution to this the long screws that connect the fans to the rad are not long enough once I try to mount on my cte 700 front fan section they are about 3 - 4 threads short does anyone know if there are longer screws. So far not impressed I've got the daisy chain cable that was somehow trapped under the hose housing from the factory and despite checking it won't fit straight in as I was told it would because the 8pin CPU connector blocks the fans so no problem I thought unscrew the fans and switch sides then I ran into the short screw issue turning into a bit of a nightmare. Thanks for any help suggested it is appreciated.
