longest cutting length...hair clippers ?
i doubt it. i didn't think it was worth using anything higher than a grade 4 with a clipper, anything longer would need to be a scissor cut surely?
the clippers I have just now has different attachments, longest length is a #8 which is 1inch
are there any on the market that cut longer ?
unlikely - longest guard I've seen is 25mm (~1") longer than that and you may as well use scissors.
I use mine with a grade 8 on the top and work my way down to a 2 on my side burns. Makes sure you don't get any steps.
And my clippers cut at an 8 fine. So talk of a bad cut is nonsense really. Depends on the individuals hair so generalisations are just bullcrap.
