Loobman installation pictures (Chain oiler)
1 Dec 2006
Amsterdam, NL
Hi guys,
I fitted something called a 'Loobman' when I fit the new chain and sprockets, it's basically a cheap mans scottoiler. Does the exact same job though.
Here are some pics:
Full assembly shot
Oil container and primer
Contact head where oil is placed upon sprocket
As you can see, any oil can be used, I have opted for engine oil as rec'ed by a few mechanics. The installation was one of the fiddliest and difficult things I have ever done, a 1000 piece mechano set would have been a doddle compared.
The bottle/prime system was easy, the location of the delivery head was not by any stretch of imagination, you have to adjust the wire, get it in the perfect spot for it to even drip the oil properly.
But, after many hours of fiddling around over the week, I have it working :D
I ran the bike on the paddock stand in second about 3k revs and primed the line 3 times, 2 lots hit the chain and as you can see the third is sat in the tube. The idea is to prime once every time you ride. I ride to work and back so that's once a day, which should do me fine.
I can say, the oil spreads perfectly and right into the chain links, it is SOOOO smooth and so easy to do once installed. I would recommend this to anyone, only if you have patience and attention to detail. Oh and a creative mind as the instructions aren't exactly step by step.
ags
I'm quite interested in getting something like this for my bike. Interesting to hear you didn't like installing it. Thanks for the heads up.
Also is that a 916? Nice.
748 :)
Love it to bits. The installation is one of those things, you need to take slowly and think about what your doing. The main reason I had such a hassle was because of the single sided swing arm, my mate has installed his on a gsxr. Said it took him a total of 3 hours, was fiddly but not bad due to the square double sided swing arm. Mine was a pain in the buttox!
ags
I've had a Scotoiler on the Mille since day one. Saved me a fortune in chains and sprockets, hardly ever have to adjust the chain.
Oooh thats reminded me to fit my Scottoiler this weekend - Ive only had it three months...
Hopefully wont be as fiddly as the Loobthang you used...
