I've got a cooler master 430 case at the moment but it's kinda getting on my nerves because of the lack of cable management so it's time to find a new case.
The thing is I've cut a hole in the perspex side panel to fit a large fan, 180mm which fits 150mm brackets (was supposed to be 140mm but doesn't fit 140mm brackets) and I was wanting to use the fan in the same place on my new case.
I don't really fancy modding my new case so I was wanting one with a mesh side panel to fit it to. The only case I've seen is the Zalman Z9 Plus Tower Case
http://www.overclockers.co.uk/showproduct.php?prodid=CA-037-ZA&groupid=701&catid=7&subcat=736
which looks ok but was wondering if anyone had any other Ideas on what I could get.
