I'm currently using:
Asrock Dual Series SATA 2 Mobo PCI-e x16, agp x8.
Athlon 3200+ at 2.0Ghz
Geforce 6800 LE AGP X8
350 Watt PSU
1.5GB RAM
SATA2 250GB DiamondMax
and I'm looking to upgrade some parts.
I'm goin for:
Hiper Modular Type R 580W PSU (peak wattage 630) £59.99 inc Vat
BFG8800 GTS
Aswel as a Saitek Eclipse Keyboard £23 inc Vat, a Gaming Mouse £13 inc Vat, and a 19" Widescreen 5 ms Monitor £124 inc Vat.
Basically, I need to know if All of them will work well together, I'm pretty sure they will, but you guys probably know more then me.
I'm on a Budget with the psu, around 60 quid max.
Also, What sorta case should I look for, I have around 40 quid to spend on one, and I thought of a CoolerMaster Cavalier 3, but I'm not sure if the grfx card will fit inside, also I need a case with good airflow, so I can overclock my system and raise it's performance.
Thanks in Advance, and any relevant / all advice will be greatly appreciated, Cheers
350 Watt PSU
1.5GB RAM
I'm goin for:
BFG8800 GTS
