- 16 Nov 2024
- UK
After many years of faithful service, my old HP prebuilt is not only showing its age but sounding and acting like some parts are on their last legs. As a result I have decided a new machine is in order.
My goals are to basically have zero issues or concerns running the games I usually play (stuff like Civ, total war, modded elder scrolls/fallout) on max or high settings for hopefully at least the next few entires in their respective series. As well as be used for day to day use, 3D modeling and if it is at all capable of something like live streaming.
The specs for what I am looking to have built using the OcUK Tech Labs AMD Ryzen AM5 Midi Gaming PC Configurator (I don't trust myself to build from scratch yet) are as follows:
My old machine consisted of:
Intel i7-4790
RAM 16.0 GB
NVIDIA GEFORCE RTX 970
1.5TB split across a 500GB SSD & 1T HDD
(I apologies for the somewhat sparse information I have on it)
I am very new to all of this so I am not even too sure exactly what scale of improvement this would even be (if anyone could put it into context it would be greatly appreciated) I hope to be able to upgrade this machine as I go too so any recommendation what should be upgraded first would also be appreciated.
I also have a couple of questions about the process of getting a custom PC from overclockers if anyone can help me with that:
I would love to be able to get a slightly better GPU like a 4070 super TI in it but the choices I have seem to be arbitrarily locked off is there any way I can get around this limitation?
What do you actually get when you receive the machine? do you get all of the manuals for the components and bits that are not used in the build but come with the components?
Do Overclockers ever do things like sales on custom PCs?
Is there any way that I can request something like the cables for the 3.5 inch and 2.5 inch drives to be installed despite not having any of those drives included in the build (I would like to try and install these myself at a later date. Start myself off with something really small in terms of PC building) Is there any negatives to having this done if it is possible to ask for this and they are willing?
- 1x Phanteks XT Pro Ultra ATX Case Tempered Glass Window, Black
- 1x Build Stock AMD Ryzen 7 7800X3D Eight Core 5.00GHz (Socket AM5) Processor -
- 1x Asus ROG Strix B650E-E Gaming WIFI (Socket AM5) DDR5 ATX Motherboard
- 1x Corsair Vengeance EXPO 64GB (2X32GB) DDR5 PC5-41600C40 5200MHz Dual Channel Kit - Black (CMK64GX5M2B5200Z40)
- 1x NZXT Kraken 240 Black AIO CPU Water Cooler - 240mm
- 1x MSI GeForce RTX 4070 VENTUS 2X E1 OC 12GB GDDR6 PCI-Express Graphics Card
- 1x Corsair RMe Series RM1000e Fully Modular Low-Noise ATX Power Supply v2 (CP-9020264-UK)
- 1x WD Black SN850X 4TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (WDS400T2X0E)
Intel i7-4790
RAM 16.0 GB
