looking build loop need advice (newish to it)
3 Jul 2014
Hello there,
So recently I did some upgrades to setup with two titan x in SLi I find they run hot and loud so looking to build a cooling loop for them.
I have a nzxt Phantom Enthusiast mid tower case.
This is my idea for Placements.
pink=Res and pump, yellow=360mm rad, blue 120 rad, purple = tubes.
Ok so I "think" I can fit a 3x 120mm rad in the top as I can't find 2x 240mm rads (if they exist please share) and with a little mod a small 120-140mm rad in bottom front.
I plan to go res/pump in the bays.
Order res-cpu-top rad-gpu1-gpu2-front rad-res.
Need advice on
1. Do duel 240mm rads exist
2. Is the rads I list be sufficient
3. Order optimal
Going to try and pick up a kit from here and two gpu blocks from ekwb.
Thanks
MS paint at it best :p
Looks fine, I would have preferred a 360 after the GPU's but given the room you may not be able to fit one in. Not sure how hot the TX's get but I would have thought 2x240's would be enough if on stock clocks
Regards duel 240's do you mean as in thickens or duel cores? EK do some 60ish mm thick rads I believe xspc do too
duel here
https://www.overclockers.co.uk/showproduct.php?prodid=WC-487-EK&groupid=962&catid=1523&subcat=1525
60mm thick version
https://www.overclockers.co.uk/showproduct.php?prodid=WC-160-EK&groupid=962&catid=1523&subcat=1525
It's a pity OCUK don't do the EK kits. don't know if EK still do them :confused: Not tried a OC kit, others will be able to comment better on them
duel here
60mm thick version
I mean like a rad that fits 2x 240mm fans per side so be like 480x240 dimensions. I'd have to get a normal thickness rad as I can't fit fans under top lid.
And yes I'd prefer to have the big rad after gpu to haha my titan x atmo hit 83 degrees max with 75% fan speed when gaming no over voltages just a 200hz gpu 400hz memory overclocks
