Looking for 10 laptops with specific requirements
  • Thread starter Thread starter BuZ
  • Start date Start date
BuZ
BuZ
26 Oct 2011
The Universe
Hello all,
I am looking for 10 laptops, specifically running Windows 7 or Windows 8. Any laptops found will need to reach and be within a certain price range of £400 at maximum.
I am looking for these specific and possible specifications:
  • 250GB - 500GB HDD (maybe even 1TB; if a little bit of money is left over and reserved, although from research this will pump the price up even more).
  • Quad Core CPU (possibly Intel i3, Intel i5 or something similar)
  • 4GB - 8GB RAM
Any laptops meeting the above requirements will need to run:
  • Full Adobe CS6 Suite
  • 3DS Max 2014/2015 Software
Acer TravelMate Extensa EX2510
Available for £339.97 if you search on Google shopping.
The place selling them for that price has plenty of models to choose from that would fit your criteria.
You're probably going to need to go second hand to meet those requirements at that price point.
I assume this is for a company, in which case id go and speak to the people who are going to be using these machines as it doesn't sound realistic. Id probably expect to pay at least double that for a suitable workstation type laptop.
Look at Medion Outlet on ebay...
MEDION AKOYA P6647
These are listed regulary and dont think they go over £350 on auctions.
Medion/Lenovo are amazng with warranty services...
yeah £400 and the ability to run 3ds max (well with any level of usability) isn't going to happen in all honesty.
Personally I wouldn't want to run 3ds max on integrated intel gpus at any price range.
