Looking for a build £500
2 Mar 2014
Looking for a build for my lil bro that will be able to run fortnite,minecraft and daily use such as work and videos.
Looking to spend £500 but could push to around £600 that would last a good couple of years before a upgrade.
Monitor and peripherals not required as he already has them.
Thanks for the help chaps.
An I3 with maybe a 1050 is probably fine for Minecraft. Then for everything else, whatever you can afford.
It's worth looking at used CPUs and motherboards as well. You can find older i5s + motherboard for under £100 and they are still fine for gaming.
My basket at Overclockers UK:
Total: £599.54 (includes shipping: £12.60)​
He could add a second drive later on. Needs Windows 10, which can be used for free to begin with. Maybe you have a key for him or can find one cheap.
