- 15 Aug 2018
Hey guys, so I am now looking for a new case, I am willing to spend between 1-300€, my current case is the Corsair Spec Alpha, its just outdated and there is little to no room for cable management etc.
My specs include (Those which matter)
EVGA GTX 1080 Hybrid FTW - Has a 2 Fan Rad attached, 240m I think?
i7 8700k with a Hyper 212 Evo on it, this would need to fit into the case for the time being, I will upgrade at some point but its just not in the budget currently
2 3'5 Hard drives, 1TB and 2TB, these will need to fit and I would hope there would be room for 1 more 3'5 Hard drive at least as thats why I am upgrading mostly.
1 2'5 SSD
New PSU will be purchased, I will be going moduler leaving my Corsair CX750M behind.
My Motherboard is a Asus Z370 Prime P ATX, due to this I have also bought a Kryom m.2 passive cooler so another PCIE slot is used.
There will be NO water cooling used ever, just not my thing. I will be using fans, as many as needed and I will be using RGB, 1 colour, none of that techno looking stuff, so a glass window is a must.
TL;DR
I need 3-4 3'5 Slots
2 2'5 Slots
Minimum of 3 PCIE slots
Fit Hyper 212 Evo
Glass Panal and as much visibility as possible.
Hold a 240m Radiator from my GPU
Hold as many fans as possible
The case I was looking at was the lian li pc-o11dx but am unsure if it will suit my needs
If anyone is willing to help, thank you.
1 2'5 SSD
TL;DR
2 2'5 Slots
Fit Hyper 212 Evo
