A mate and I have approx £40 for modding a case - a gift for another friend's Birthday come mid-september.
We basically need to find a case with good internal layout, MUST have a front and rear 120mm fan vent for mate's fans. Any light colour preferable.
Since we're either gonna use grey duck tape or "Fragile" tape and basically go all out mental on it (we've got like 3 rolls each here
) we'll need the case to be as flat on the front as possible - easier for duck/"Fragile" taping. The plainer the look, the better. We'll not tape the back or bottom panel. Depending on how the front in-vent is shaped, we will tape over and cut out the grill.
My mate's leading the Project: Gift Taped and I'm the case hunter. Any suggessions will be appreciated.
) we'll need the case to be as flat on the front as possible - easier for duck/"Fragile" taping. The plainer the look, the better. We'll not tape the back or bottom panel. Depending on how the front in-vent is shaped, we will tape over and cut out the grill.My mate's leading the Project: Gift Taped and I'm the case hunter. Any suggessions will be appreciated.
But it does have completely plain sides, a flat front and no window
