Looking for a case need help
12 Nov 2011
so i have a "Thermaltake VA8003BWS Armour Super Tower-Black" and its a bit old now and would like a new one...
was looking at Cooler Master CM-690 II Advanced Dominator Case
http://www.overclockers.co.uk/showproduct.php?prodid=CA-196-CM&groupid=701&catid=7&subcat=29
would go up £100 or £120..
I picked this case cuz i have 3 hdd and want to mount one hdd next to my blu ray drive with the brackets in the box..
The other 2 hdd below and then remove the lower hdd caddy to give better air flow to my gtx580
Computer Setup
PNY NVIDIA GeForce GTX 580 1536MB GDDR5
Acer 23.6" 120Hz 3D Widescreen LCD Monitor
NVIDIA 3D Vision
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66GHz @ 3.20GHz (Socket LGA1366)
Zalman CNPS10X-Performa CPU Cooler Socket Intel 1366
Gigabyte GA-X58A-UD3R Intel X58 (Socket 1366)
Patriot Viper 6GB (3x2GB) DDR3 PC3-12800C8 (1600MHz) Low Latency Tri-Channel
Samsung SpinPoint F3 500GB SATA-II 16MB Cache X 3, 2 IN RAID 0
Creative Sound Blaster X-Fi XtremeGamer Fatal1ty Professional Series 7.1 Sound Card
Enermax Infiniti 720W EIN720AWT ATX2.2 Modular SLI Compliant PSU|
Heres a few more, no particular order,
http://www.overclockers.co.uk/showproduct.php?prodid=CA-237-CM&groupid=701&catid=7&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=CA-060-CS&groupid=701&catid=7&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=CA-057-CS&groupid=701&catid=7&subcat=
The last suggestion from me is another Raven
http://www.overclockers.co.uk/showproduct.php?prodid=CA-065-SV&groupid=701&catid=7&subcat=1092
But there are a few versions of this case,
RV03B Basic and Black.
RV03BW Black with a window.
RV03B-E Black with the air penetrator fans
RV03BW-E Black with a window and the air penetrator fans.
Go with an Antec 1200 - Easy to clean, perform well and look the part!
Purchased mine for 120 about a year ago and still going strong... would recomming most of the Antec Series.
