Looking for a case of a specific size.
26 Jul 2012
Hi there,
Would anyone be able to recommend any specific cases or somewhere I can narrow my search by dimensions? I'm looking for a case that can fit an ATX board and be no more than 455mm (Deep) and 440mm (high), width isn't a problem. I've currently got an old Raijintek Arcadia case that is 455 (deep) and 430mm (high) that I'm looking to swap out when I upgrade. Thanks
The 011D is very close to that size. 272 x 446 x 445 mm (W x H x D).
I'm currently waiting for the 011D Mini which will fit a full size ATX, but will be a fair bit smaller than that.
Raijintek Thetis
210 x 360 x 366 mm
Fits ATX motherboard and ATX psu
Thanks for the suggestions. Are there any cases that fall within that bracket that don't have a glass panel?
