Looking for a case that can accommodate two builds with two PSUs
19 May 2020
Hey,
I'm looking at building a 2-in-1 computer, i.e. 2 systems in 1 case.
I've already got 2 PSUs and would not want to buy a specialist PSU that can split across two motherboards.
Is there any case that you could recommend that fits 2 PSUs (650W and 1200W)
Cheers!
this is a pic when i had 2x PSU, also i have switched the ITX cooler to AIO. Really mine is back to front you want the MATX system as the main and the ITX as the second
Been thinking about doing something similar and struggled to find options
Consdering getting 2 thermaltake core v21s and stacking them
Gives a bit more flexibility in case I ever want to separate them. :( Problem is motherboard size limits you
How are you planning to use the two systems? You'll need to be very careful that everything is super cooled as heat and airflow become twice as important.
