Basically I bought a full-length SCSI card, and it won't fit in the case because of the silly 5/6 HD bays built into the case. Can't dremel any out either, because they're supported from the base.
So, I'm looking for a case which has the following:
- Capable of holding 3-4x hard-drives - preferably using internal 3.5" bays
- Has the capacity for a floppy-drive, as well as the 3-4 hard-drives
- Has no less than 3x 5.25" bays
- Not a must, but I would like easy access to the motherboard - ie: you can put a full ATX motherboard in, without removing drives.
