Looking for a case!
Neg
Neg
Permabanned
11 Mar 2009
Newcastle - Near Stoke
Budget is £125, has to cool well, maybe fit watercooling.
PC specs to fit inside are.
E8500 + True
ATX Mobo
GTX 260
4HDD's
2 Optical Drives
So, spec me up!
i can verify the case edgey says is a great cooler!! but i don't have watercooling so i don't know how easy it can house it!
From pics Ive seen it does seem quite roomy however obvious size of your kit but you shouldn't have a problem id have thought
That antec 1200 is a bit ugly.
What about this one, hows if compare to the Silverstone and Antec?
And how do these compare?
Item 1
Item 2
As you can tell, i like the plain/rugged look.
Item 1
Item 2
I really like the Zalman you linked to, no idea what its like for water cooling though, that CM looks a bit small and the HAF is as ugly or maybe worse than the Antec 1200 IMO.
Lian Li A70 & 71 I know have loads of room for watercooling, I have a triple rad in the top of mine.
Still cant decide, so are these 3 any good? (Dont want flash and flare, something subtle and rugged)
In the reviews for the Coolermaster RC-1000 Cosmos someone mentions they are using watercooling so it will fit. Its a full tower so has lots of room. Good looking case too.
How about the Akasa Omega? That would seem to fit the bill. Also might be worth having a look at the Aplus Black Pearl range and can't go wrong with the Lian Li or Silverstone cases mentioned.
:D
