Looking for a compact ATX case
X3T
X3T
12 Sep 2011
I'm looking for a compact ATX case for my new PC. By compact I mean pretty much as small as you can get whilst still fitting a full ATX motherboard in.
It's the height I'm looking to reduce, the width and depth should be around normal tower specs (I don't like the extra wide cases like the Corsair 540.)
It must also have a large side panel window, mounted flush or on the inside.
The only one I can find is the Corsair Graphite 230T
Unfortunately all the cases this small seem to be budget ones, so build quality is a concern.
Any suggestions?
