Looking for a decent printer, ~£50...possible?
11 Oct 2005
Manchester, UK
I've just started university and I've come to the realisation that for the price it costs me to print at university, it would only be marginally more expensive to buy a printer for around the £50 mark to have at home.
Does anybody have any recommendations of a printer for around £50 or are they much of a muchness? I'm also curious about the print/scan/copy machines, are they any better/worse than a simple printer?
Cheers.
Canon MG5150, really good prints and packed full of features. I printed all my wedding stationary and it looked amazing.
I have a Dell 1130, grabbed it for £25 including laser cartridge :).
I'd want a laser if I was in your position, given the work you'll be printing will be mono anyway?
HP C4580 - A little bit out of budget, but the ink is so damn cheap, and its wireless, which is a plus, you can hide it and still be able to print.
go kodak...you may pay slight more for the printer (think the printers are about £70 ish) but you will pay a lot less for the inks....
canon (while having better print quality) there inks cost a lot...
If you can find a £50 printer then install a CISS (continuous ink supply system) it should last a very long time. :D
