Hi All,
Back in 2014 I built myself a nice PC and have used it for a couple of hours daily, 4 hours a day max and primarily for website design and Get iPlayer.
It has never let me down so I've had no reason to stay in the loop with PC hardware development etc, last week I decided that I would like to build a new PC and move onto Windows 11 but it seems there's a hell of a lot more options out there to choose from now than back in 2014.
In a nutshell, I'm looking for something that runs Windows 11, can be used for web design, Get iPlayer and probably the Any Video Converter program as I would like to convert some of my iPlayer recordings into a format that can be put on to a DVD/Blu-ray disc.
I think the AMD Ryzen 3 3100 or it's Intel equivalent which Google says is the Core i5-9400F should be decent enough for what I need? but I would like to go a little bit better than them I think as I'm not intending to upgrade it again until 2034
Any suggestions?
Once a year I totally strip the PC down, clean the fans, change the thermal pace, get rid of any dust, open the PSU, get rid of dust and inspect the capacitors etc - that probably hasn't contributed to it being so reliable but I just like to look after it.
Also any idea on whether I'd be better sticking with a normal hard drive or getting an SSD? or an M2?
A few posts online say SSD's are not recommended for small files that are being edited regularly (I'm assuming that includes HTML files) my Get Iplayer files are 400mb - 600mb and when I convert them they go down to 200mb, are SSD's suitable for converting video files?
Any recommendation and advice would be greatly appreciated
Any suggestions?
