Hi guys, first time for me here in the case forum, but i could do with some of your expertise.
I'm looking to spend £200 (ish) on a full tower sized aluminium case, but i can't find one that doesn't come with any problems or issues.
I'm looking for something with a traditional design, so no need for any 'fashy' bits, side windows and the like.
I really like the Lian-Li PC-V2000B, however, in reading the following review (http://www.abxzone.com/abx_reviews/keri/article_p3.html) it is noted that some of the larger heatsink/fan combos such as the Zalman CNPS 7700 or the Thermalright XP120 won't fit in the case due to the partition between the motherboard area and the power supply area, therefore ruling this out as a possibility.
I also really like the Lian-Li PC-G70, but as i only use one power supply, i don't fancy having a gaping hole in the top of the case where the second power supply would go.
I am, therefore, rather stuck and if there is anything that people can recommend i'd be absolutely delighted to hear about it.
Many thanks for you time
Spudgun
Spudgun
