Looking for a Goldilocks mouse.
22 Mar 2015
Kent, UK; Brooklyn, NYC, NY
I'm currently going between a Razer Mamba Elite (wireless) and an Asus ROG Spatha (also wireless). I also have a Corsair Dark Core I use on another system. None of these mice are great, in my view, for my hands and use case. I primarily play RPGs with some shooters, and I use primarily the right, left, and scroll wheel/middle buttons. I have mostly a palm-fingertip grip.
I don't need a multitude of extra buttons and settings. The Razer is a bit too small, the Asus too heavy, and the Corsair is a bit too short (although closer in shape to what I want). I have big, thick powerlifter hands and need something substantial to grip, but not overwhelmingly heavy.
Ergonomically, the best mouse I've used was Mionix Naus, but this is only wired and has limited DPI settings. Anything close to this in shape, but wireless with a good sensor?
Also look at the Logitech G G502 HERO which has adjustable weights I believe.
Yes that's true, the newer X models with the Lightforce switches don't have the adjustable weight system. I’ve had both, and personally although I always thought I wanted a weightier mouse I actually find the lighter G502 X nicer to use. It also has newer features like the LIGHTFORCE switches and updated buttons. But yeah the HERO’s adjustable weights are better if you do prefer a heavier mouse.
The only downside to the 502 is I find the side buttons occasionally do a double click when you only press them once. The Lightforce switches fix this for the main top buttons but not the side ones which can still have this issue.
