- 22 Sep 2020
hi all looking for a good case for a 11900K thats small as need to fit it on entertainment center with good cooling also no rgb on case or the ablity to disable it or remove it
Good case, as compact as you can get without going ITX.
Good cooling? In essense it can only fit 2x120 on top and 2x120 on bottom/rear. So not much
Wouldn't recommend using it with GPU above 250W
What gpu you getting think the case is limited to 270mm long.
11900k chucks out some heat maybe the 5800x is a better fit.
Heres one option case is slightly longer.ah ok whats the smallest case that could fit a Noctua NH-D15S and a 2080 ti ?
im trying to get a 3080 ti when it next comes back in stock for my main pc and puting in the pc i'm building my old 2080 ti
