Looking for a MoBo.
Dont think there are any ASUS boards that are E-ATX for under £200, theres an old P67 WS at £206
http://www.overclockers.co.uk/showproduct.php?prodid=MB-477-AS&groupid=701&catid=5&subcat=1906
http://uk.asus.com/Motherboards/Intel_Socket_1155/P8P67_WS_Revolution/
But you should be buying a Z68 board.
This is ATX,
http://www.overclockers.co.uk/showproduct.php?prodid=MB-493-AS&groupid=701&catid=5&subcat=1990
http://uk.asus.com/Motherboards/Intel_Socket_1155/P8Z68VGEN3/#specifications
Put the sound card in top 1X slot and the two GTX560ti's in the Blue/White 16X slots which then run at 8X/8X.
Well i found this motheboard!!
Has anyone used this board before or heard anything good about it.
Asus Maximus iV / E-ATX / Z68 / Gene-Z/GEN 3 Socket 1155
Going for around £146 inc VAT.
E-ATX is extended ATX, bigger than normal. mATX is micro ATX which is smaller than normal.
It's very unusual for someone to be specifying e-ATX, but common for someone to require mATX.
Are you sure you want E-ATX?
Yes i would prefer the E-AtX
Ok it seems the product specification is rather confusing at 2nd viewing.
Firstly it says Asus Maximus Socket 1155 DDR3 SATA2/3 HDMI GbLAN Ch7.2 EATX MainBoard
then is says ....
Fully PCI-Express 3.0 Ready, Intel Z68-mATX gaming board with LucidLogix Virtu switchable graphic technology
Then once again it says .....
Motherboard form factor Extended ATX
