Hi, I have this laptop:
http://www.msimobile.com/level3_productpage.aspx?id=311
as you can see, the video output is VGA (15-pin, D-Sub) X 1, HDMI 1.4 X 1
I want to buy a couple of led monitors, and as i want them to be the same model, i'm looking for one that has this kind of connections. Does this one have this characteristic?
http://overclockers.co.uk/showproduct.php?prodid=MO-032-AS
It says: Signal Input : HDMI , D-Sub, DVI-D
Is D-Sub the same as VGA 15-pin? Is the HDMI input "1.4"? Thanks in advance.
