Looking for a narrow case to mod to fit external 360 Rad and fans.
21 Jun 2006
UK
Does anyone know of a case as cheap as possible which I could mod to fit a vertical 360 rad and fans in?
I'm just trying to tidy up my external rad setup.
The only caveat is that it need to be under 17.5cm wide.
I'll be gutting the internals of any drive mounts etc.
If i can't find one ill just make something, just thought this may work out cheaper.
You could build a wooden/metal/aluminium frame and put aluminium on it and paint it that way you get the perfect fit for your parts.
True, that is something that I considered.
With the prices of some cases these days I thought It might be cheaper to just buy a slim atx/matx case though.
You could still get a cheap case and take out the motherboard tray for more room,I used to have a shuttle pc and was going to use that for a rad box.
Have you had a look at the b grade section in the shop there are some cheap cases there.
