Looking for a new 27 inch for under £200
25 Apr 2009
I just want a quality 1080p monitor with good colour/contrast/viewing angle/refresh rate, and a good height adjustment. I play FPS and racing sims mostly. I see a lot of talk of anti flicker? I do spend a LOT of time in front of my PC, so if that's a valid technology it would need that too.
Cheers.:)
What's wrong with the B1? All I can find is the B1, even if you search for XB2783HSU-1, when you click the links, it comes up with XB2783HSU-B1.
Yes it does, in fact the stand was one of its strengths. NOT to be confused with the XB2783HSU-B1
The B1 is with a ****** stand (same monitor), while the -1 is with the good stand. You can find it if you look around the... biggest online shop. Can't say where on forum.
I guess if you can put up with the lower grade stand go for the B1. I note that it is around £30 cheaper with the non-adjustable.
