Looking for a new Android with wireless charging.
13 Jan 2013
I'm looking for a new Android with wireless charging.
I'm sick of USB charging ports.
On My last 4 handsets all the charging ports have become a pain in the rear.
What else do i want ?
A minimum of 5000mha battery the bigger the better.
I just want the battery to last more than a day and not have to worry about a charging port going mammarys up.
Thats it simple really.
Budget? What do you usually do on the phone?
Pixel 6 series is a good one to look at if you want long battery life.
Use it as a phone , browsing , socil media. Camera is not important.
Budget , anything. It dosent have to be the newest or top of the line.
Will have a look.
Still not certain on UK release, but upcoming Oneplus 10 Pro supposed to support 50W charging with the appropriate charger. But depending on your budget, i would guess the phone is going to be somewhere in £800 to £900 range and the charger likely at least £50, probably around £75
It'll be pricey for sure.
