I've been out of it for a while with regards to buying hardware but I "think" I've specced up the right kit...
I currently have a P 2.4, 1GB ram with a 6800GT, would I notice a big increase with the spec below? Comments welcomed.
Also should I have Win XP or Vista??
XClio 6030 PLUS Black Midi Tower Gaming Case ,
OCZ StealthXStream 500w
Gigabyte GA-N650SLI-DS4 S775
OCZ 4GB (2x2GB) PC2-6400C4 800MHz Reaper
Intel Core 2 Duo E6750 Socket 775 4MB Cache Retail Boxed
Western Digital Caviar SE16 500GB SATA-II 16MB Cache
Creative Sound Blaster X-Fi Xtreme , OEM , 7.1 channel , PCI
XFX GeForce 8600 GT Fatal1ty 256MB GDDR3 HDTV/Dual DVI (PCI-Express)
Cheers for any advice.
its all done in bios. There are softwares that you can use for oc but its better in bios. If you have a look in CPU section you'll find all the info you need to oc.
