Hi there havent been here in a while
my old build which is used by the oh needs a cpu cooler rough specs are
msi 870-c45 board
amd phenom ii x4 955 overclocked to 3.6
2x 4gb mushkin blackline 996995
master cooler cpu cooler not sure of model will attach pics
case zalman i3 edge with front plastic removed to actually give it air flow
Was gonna order the cooler master hyper 212 evo but my case only supports 156mm high cooler where the evo is 159mm high
ive also looked at the deepcool gammaxx 400 which is close to limited height of 156mm coming in at 154mm and not sure if memory height might be issue
any thoughts on this cooler or any recommendations ideally good but under £30
Few pics and yes its old lol
Cheers marc
msi 870-c45 board
Cheers marc
