- 8 Feb 2008
- UK
So went to turn the PC on this morning and machine started up but the nothing appeared on screen - It's a fairly old 17" E172FPb Dell TFT that came with the workstation [Dell Precision 360] The green 'on' LED was flashing on/off and the monitor screen would occassionally flicker, hooked it up to another PC and it did the same, went online and looks like its dead according to others - I spose it's lasted about 8 years which isn't that bad.
Anyway the short of it is I need a replacement. Thinking of spending £100-150, would I be right in assuming 22" is the sweetspot in terms of price and size?
The PC outputs to VGA and DVI, though the Dell monitor only took VGA. I'd prefer to use the DVI now which I imagine will be pretty much standard on most monitors, so no need for any fancy outputs like HDMI or DP.
I don't suppose there will be any problems with the Dell workstation graphics [nVidia QuadroFX-500] pushing 1920x1080?
Anyway I'd love some suggestions for a decent monitor in that price range. I've seen the two 22" Asus monitors on TWO which look ok, there a couple of BenQs and there seem to be quite a few 23" Samsungs.
Any help is much appreciated - looking to order today if I can.
