Looking for a small case
17 Apr 2010
Dimensions can be no more than:-
37cm (W) 9cm (H) 38cm (D) Max
Ideally I am looking to fit a A10-5800K, so looking for a case which could support a PSU (internal or external) that could drive this, however I am realistic to using a 65W CPU though if necessary due to PSU limitations, I am willing to perform case mods if necessary to get the right PSU (but would prefer not to).
Thanks for any help / advice.
Chris.
Thanks MORE SPEED. I guess it's just the way that picture is
@ vanandjuanunited ideally, 2x 2.5" HDD's, and a bluray drive, although with the above case, with a 2nd HDD you only have 24mm clearance for a CPU cooler, and I might struggle with that! On that subject what CPU cooler should I go with given the limitations?
